Question about Euro-Pro Shark 60 - 384
I am having a problem with my Shark Intell-Sew that I've had a few times before but I've always been able to resolve it, and this time I can't. The machine jams, and the book says it's usually because the feed dogs have lint in them or the inner mechanism is dusty. I usually can take off the metal plate, remove the bobbin holder, use Dust Off to clean it out as well as the brush that comes with the machine, clean off the feed dogs, and once I put everything back together it works again. My daughter and I have been battling with it all day (we have a birthday party tomorrow, and we're trying to finish up the favor bags!!!), and cannot get it to work. Any advice?
  • 11,896 Answers
Many machines today have a horizontal thread delivery for the needle thread. Be sure and place the thread spool with its tiny notch on one end (the notch is used to secure the loose thread end when not in use) facing toward the far right side of the spool holder and not facing toward the left side where the thread will be guided off the thread spool into the vertical tension discs and toward the needle. Some times this tiny notch will catch the thread causing undue thread tension on the needle thread. Placing the thread spool facing toward the right seems to help the thread guide off the spool without catching in the tiny notch.
Also hold onto the needle thread and the bobbin thread, giving slight hand tension to both, for the first few stitches you make in your fabric. With the first uptake of the needle, the needle’s thread tail and bobbin tail are drawn down somewhat loosely into the bobbin case and can become tangled and jam if not held onto briefly. Be sure the bobbin thread comes out of the needle plate in the area it is intended to. After winding a new bobbin, it may help to put the bobbin in its bobbin case and just raise the machine needle by hand just enough to allow the needle to bring up the bobbin thread to the top. Give the bobbin thread and needle thread held together a slight tug so that they both lay out behind of or to the side of the needle. If you have left off the needle throat plate for last (for those machines that allow the throat plate to be removed) when placing the throat plate back on the machine, be careful to guide the bobbin thread through the hole or space in the needle throat plate so the bobbin thread lies on top the plate.
Using the right machine needle for the fabric helps too. Generally, ball-point needles work great for knits and sharp-pointed needles for woven fabrics. Using the smallest size needle that makes the best stitch for the type of fabric seems to work well for most fabrics to produce clean even stitches.
Using the best quality thread helps. The bargain-priced threads found piled in sale bins at the fabric store work great for hand sewing but not for machine sewing. Lesser quality thread make lots of fuzz as it passes through the needle and can jam the machine. Many sewing machine repair folks hate the thought of us using a can of compressed air to blow out fuzz from the tiny spaces of the machine, particularly the newest digital electronic machines, but a spritz or two of compressed air in the vertical thread slots that hold the tension discs and in the bobbin case itself, usually can dislodge bits of fuzz from these spaces. Although compressed air is not recommended for a new machine the thought is offered for you to consider for older, mechanical machines.
Posted on Sep 12, 2009
My CE5000PRW the wheel well not move and it keeps coming up e6 but it just wont sew... HELP!!!
To find out what the error means, search for:
Make Model (error code)
Depending on what the error is and whether it can be user-corrected, it may need to be serviced.
Nov 13, 2017 | Brother Sewing Machines
Machine starts to sew then upper thread knots up on underside of fabric
Do each of these steps one at a time and then test a seam on scrap fabric of the same type.
1. Make sure you thread the machine correctly with the feed dog lever in the up position. (this opens the tension discs, allowing the thread to seat correctly)
2. Make sure your needle and thread are the correct size for the fabric and that you've oriented the needle correctly and have it fully seated into the needle bar.
3. When beginning to sew a seam, always grasp both threads and hold them as you begin to sew.
4. Loops on the bottom of the fabric means that the upper tension is too loose. Tighten the upper tension a little at a time until loops disappear.
Good luck.
Sep 22, 2012 | Brother XL-2610
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
I have a Euro Pro Shark Automatic. It works perfectly as a rule. I am trying to sew heavier material than usual - new inserts for my exterior sling chairs. The thread is heavier nylon and it catches on...
Most domestic sewing machines will not handle heavier thread than the standard 50 weight. I'd suggest you go back to regular polyester sewing thread and use a 110 or 120 size needle to cope with the heavier fabric. Sew slowly and give it some help on the flywheel when crossing a seam allowance. Maybe stitch each seam twice, with a 1mm gap between to give it strength.
If you need to use the heavier thread to do the job then you will probably need an industrial sewing machine that can handle that grade of fabric and thread. Something like a Singer 20U machine in a table with seperate motor drive.
Fabrics like Canvas, ticking and PVC for exterior items are generally going to be beyond the functionality of a domestic machine and you can damage the machine, particularly the timing by trying.
Aug 23, 2011 | Euro-Pro Shark 80 - 7133
Need manual for shark sewing machine and phone
I've done searches thru all of my sources for a free manual many times for 384, but never found one. I've only found one site that offers them for pay. It's at http://www.sewingpartsonline.com/instruction-manual-euro-pro-384.aspx.
I'm afraid I've never found a service number for them, either, but you may well be able to find one in the manual. Best of luck to you. Maybe you could post the service number on the site for others if you finally get it.
Jun 22, 2011 | Euro-Pro Shark 60 - 384
My Euro-Pro Shark machine is not sewing. The top thread is not grabbing the bottom thread therefore it will not sew. I have cleaned, adjusted the settings and nothing seems to make it work..Help !!!
Did you try a new needle (flat side facing rear of the machine)? Sometimes a burr on it or being bent stops it from picking up the thread. Other than that, it may be the timing on your machine and unfortunately it needs to be done by a professional with expertise and special tools.
Jan 20, 2011 | Euro-Pro Shark 60 - 384
When i attempt to sew the cotton does not sew it just breaks and
There are only a few adjustments that you can make. Over time the adjustment get so far out that the machine will need to be serviced. These folks are true pro's. They have the specialty tools and patients to fine tune sewing machine's. I have ours serviced about once every two years or so. They go through them with a fine tooth comb. Hope this helps. Good luck.
Nov 26, 2009 | Sewing Machines
Manual
I have a pdf copy of a Euro-Pro Shark 417 manual and am willing to share.
Oct 14, 2008 | Sewing Machines
Machine won't sew
Change the needle and be sure the flat side is to the back. Rethread the machine. Remove and reinsert the bobbin. Hold the top thread and turn the handwheel to see it the top thread will pick up the bobbin. If yes, it should sew ; if not, it is probably out of time and needs to be seen by a technician.
sewman7
Jul 15, 2008 | Euro-Pro Shark 60 - 384
Euro-Pro Shark 60 - 384 Logo
156 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
