Question about Ariens 34 In. Zoom Series Riding Mower
Engine turns over but no spark at plug. changed plug , still no spark. On 18hp courage sv470-610. note: has no oil sentry pressure switch.
  • 123 Answers
Ok, the way to trouble shoot your electrial system on your mower is first unplug the wiring harness at the engine. Now pull the plug or pluggs and put one plug in the plug wire and ground the plug to a paint free place on the engine. Now using a jumper cable (you only need one) from the mower battery postive post and push the other end to the bolt on the stater that holds the red wire on the starter. Watch the plug to see if it is firing . If not you have a bad coil, but if it is you have short circut in the switch or wiring.
Posted on Sep 12, 2009
2001 chrysler town & country oil light is on
If you are taking the car to the garage or a mechanic, mark the oil filter before leaving home to make sure the filter is changed. After the oil has been changed when you return home you can check the filter to see if it was changed because the oil will only be changed. Since some mechanics know an owner of a vehicle will not check. Also, AutoZone have a very good quality oil for the chrysler town and country. Good Luck
Feb 19, 2013 | 2001 Chrysler Town & Country
OIL LEAKING INTO THE SPARK PLUGS ON 2005 MALIBU CLASSIC
ENGINE OIL ISSUES/ OIL LEAK
The oil is getting leaked from its running area. The oil pump has to be pressure tested by pressure test to confirm the leak and area of leak: -----
For step by step troubleshooting check the help links mentioned below: -----
Click the link below: -----
Water in engine oil?
http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
High Oil Level on Dipstick
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Oil pouring out from left front of engine?
http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Kia Sportage leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Toyota Corolla leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Overfilling oil in engine?
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
2000 Dodge Ram 3500 Cummins Diesel: Oil Leak issues?
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
HOW TO RESET OIL CHANGE INDICATOR?
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These details will help.
Thanks.
Dec 05, 2012 | Chevrolet Cars & Trucks
1993 chevy caprice classic wagon 5.0 8 cylinder hads a problem with engine shutting off with in seconds after start ! i did check for vapor lock in gas line, had new spark plugs replace, new fule...
Think the oil pressure switch keeps the fuel pump running once started. Suggest replacing Oil pressure switch. And no it won't effect oil pressure reading when it goes bad. The switch is a safety device. When you roll it over and the oil pressure drops the switch cuts off the fuel pump. Neat huh? Need some good feedback Thanks!
Jul 21, 2011 | 1993 Chevrolet Caprice
Craftsman LT1000 riding mower with 18hp B&S engine. Mower acts like the battery is almost dead. Will try to turn over but doesn't seem to have the power to cycle the engine. New battery, starter,...
There is a compression release device on the cam shaft to allow the engine to spin easier when starting. This is likely the culprit because the starter isn't strong enough to push the engine past full compression. The fix is to replace the cam shaft.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil pressure light is on and oil is on one of the
1st check quality oil and filter, if oil and filter is good, then remove engine oil pan , clean oil pump strainer, instal oil pan , add new oil and check.
if have oil on spark plug inside of cylinder, you need to overhaul the engine, if oil is over the spark plug ,change the valve cover gasket
Jul 20, 2010 | 1995 Lexus ES 300
I have a maxim 400 it was runnning fine I change the oil and oil filter and now it won't start
Some vehicles have a pressure switch that is subjected to oil-system pressure, which must receive pressure to allow the ignition to function. This guards against lighting off an engine before it has oil pressure.
Sounds like you have one, and you need to crank the bike enough to fill the oil pump and filter back up.
Try removing the plugs, and cranking the engine for a while to get the oil system back to normal, then replace the plugs and start it.
If you do not have such a system I would look for a wire somewhere off to the side that accidentally got disconnected while you were working on the filter.
Check to see whether the bike has spark (Put a loose spark plug in one of the plug wires, lay the plug on the engine then crank to see if there is spark).
Jun 15, 2010 | 1983 Yamaha XS 400 L Maxim
MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
Apr 10, 2010 | Garden
B&S ELS 725 on a Husq 2448 lawn tractor - stoppe running won't st
There is no oil pressure switch to save the motor. You may be ok if the oil level did not drop too low. Change the oil, recharge the battery, put in a new spark plug and fresh gas. You may be lucky and have it start with no damage. good luck
May 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine won't turn over
Pull the spark plug back out and try to turn the engine over. If it doesn't move then the engine is probable seized. Was the engine oil res. full of oil and was the color acceptable.
Apr 28, 2009 | Karcher 2500 PSI Pressure Washer
Help have no spark
I had the same problem with 1991 s10 blazer.
check the oil pump pressure switch and current to the switch.
The computer will not allow the spark plugs to fire if the oil pressure switch is not sending a signal to the computer that the oil is flowing.
My problem was a short in the wiring that was not sending enough current to the oil pressure switch.
I had to crank the starter three or four times at 5 second intervals until the current was suffient to operate the oil pressure switch.
The switch is a round cylinder device located on th drives side of the engine near the oil filter.
Good luck!!
Jul 28, 2008 | 1991 Chevrolet S-10 Blazer
Ariens 34 In. Zoom Series Riding Mower Logo
178 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
