Question about Panasonic TH-42PX60U Television
Panasonic plasma hdtv will not power on--no blinking LED, simply no LED. Other objects plugged into same surge protector are fine; no evidence or suggestion of a power surge.
    President:
  • 1,077 Answers
The power supply board itself maybe the main problem inside the TV. Or, it maybe something simple like a blown fuse. Replacement fuses can be found at Radio Shack or some other electronic supply store.
If it turns out the TV keeps blowing fuses, the main power supply may need to be replaced. You can find replacements at a good price at Shopjimmy.com
Posted on Sep 12, 2009
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
Hello i have a panasonic TC-P50S1 plasma tv (2009) and it does not turn on properly anymore. You turn it on and then it turns off and start to blink repeatedly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 16, 2014 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Panasonic plasma flashing red light
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 11, 2013 | Panasonic Silver Tilt/Tilting Wall Mount...
I have a 51" Panasonic Rear Projection HDTV,
Aug 12, 2013 | Televison & Video
My 51" Panasonic CinemaVision rear-projection HDTV
Panasonic TH-58PZ850U, red LED light blinks 6 times..TV will not turn on
Aug 08, 2013 | Panasonic TH-58PZ850U 58 in. HDTV Plasma...
No power to the display at all.
The number of blinks will tell you what is wrong. This page will help.
Jan 17, 2013 | Panasonic TC-P50G15 50 in. Plasma HDTV
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Nov 20, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic TH-42PX60U Television Logo
445 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
