Question about Motorola Mobility RAZR V3
The phone is working but the display screen is blank. What do I do ?
Htc blank screen
If the phone is powered on and there is no display(Blank screen) your LCD most likely is bad and needs to be replaced. I have worked on two phones that had blank displays and a new LCD did not fix the problem(main board problem) but this is extremely rare.
Jul 15, 2014 | HTC Cell Phones
Nokia e71 blank screen
If the phone is working good without showing any display on the screen , the first step is change another LCD and if the problem still persist contact mobile repairing shop to change the display IC or check it out all the display related components.Good luck
Feb 01, 2012 | Nokia E71 Smartphone
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
The display stopped working, Just a white blank screen. The phone still works but the screen does not. Can't see who is calling and can't retrieve pictures.
Hi,blank screen is usually caused by bad screen or flex depending on the type of phone you are using at the moment.
If the phone is a flex phone that means you will need to check both the screen and the flex.(flex makes the screen to display).
When you replace the screen,the phone display will be working again.
Have a nice day.
Sep 01, 2010 | Cell Phones
Display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Jun 06, 2010 | Panasonic GigaRange KX-TG5432 Cordless...
Nokia n95 8gb blank screen
hi the main problem is not in ur display screen. the lcd is ok. but inner connections might have got damaged.
Jan 19, 2009 | Nokia N95 Cellular Phone
Blank display
when i turn on the phone both internal screen and external screen is blank please help me
Sep 16, 2008 | Motorola Mobility i850 Cellular Phone
Blank Screen
6300 blank display what to do
May 14, 2008 | Cell Phones
Blank screen
The problem has been with your SCREEN & DISPLAY UNIT. Take it to the Nokia Care with ORIGINAL PURCHASE BILL and they'll change the Display Unit.
Apr 26, 2008 | Nokia N95 Cellular Phone
Motorola Mobility RAZR V3 Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
