Question about Canon CanoScan LiDE 25 Flatbed Scanner
Saving scanned images
When I scan documents onto my mac -- where are the images saved to?  First time using scanner, would like to save a bunch of images to one pdf file if possible.  Thanks!
  • Anonymous Mar 20, 2014
    how do i move a scan wirelessly
I need Canon CanoScan LiDE20 Scanner Driver for Windows XP
Posted on Jun 07, 2008
Scanning - When I scan a photo, how can I then access it. I have Picasa 3 software
When you scan a photo or document, the computer will need to save the new document somewhere on the system. You should determine (before the scanning process) where that document is being saved and what name it is being given.
Jun 23, 2016 | Epson Office Equipment & Supplies
Saving appended files in Scandall 21 version 4.3.17
when you are saving the file make sure you are saving the file in the desired format ... the save as type option.
Jul 14, 2008 | Computers & Internet
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
How do you scan a document and save it onto the
when you install the program ..it has a software for scanning ...open that program and press scan ...after it scans it has a folder where it saves the jobs...( inside you can just open it full and copy paste for saving) another way its to manage with a picture manager that has a import from device feature ...and act just like you importing a picture from a camera ..only that you choose the scanner when you are asked for device...
Dec 20, 2009 | Computers & Internet
When I save a scanned document you increase the file size. Please. Thanks.
Document size can be set before you scan.
Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
Example, Black and white or greyscale scans are much smaller in size than color documents.
Saving files as jpg will compress the file for storage.
If you have an image editing program you can decrease the size of the file after the scan.
Dec 09, 2009 | Kodak Office Equipment & Supplies
My HP F4210 can´t create PDF format from scanned documents. I run VISTA. Stefan
It's not the scanner that creates the PDF, you need scanning software capable of saving scanned image as PDF. loaded on your computer. The software determines where to send and how to save a scanned document.
Nov 27, 2009 | HP Deskjet F4210 All-In-One InkJet Printer
Problem scanning multi page document
You do not say which software you are using but if you can afford PixEdit you can save to multipage tiff, Pdfs and so on. Also combine singlepage and mulitpage documents to one mulitpage and vice verca.
May 05, 2009 | HP Scanjet 8350 Flatbed Scanner
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Scanner problem
Hi BethKay,
What it's telling you is that the "filename" that the scanner/software package is trying to use to save the document being scanned to your hard drive has reached it's limit in the amount of times that it can be incremented by "1". In other words every time you scan a document it is saved to a directory or folder on your PC under a filename which is probably assigned by default. This filename has a "suffix" which is also assigned by the scanner/software eg. filename01.tif (or jpg, etc) filename02.tif filename03.tif and so on. Either I'm way off base or you must have scanned a whole bunch of documents using this naming convention because the scanner/software has run out of numbers that it can affix to each individual file. What you need to do is either 1. Change the folder that you are saving the documents to or 2. Change the pre-suffix filename in order to retain individuality.
Make sense?
Let me know if this helps and good luck.
J
Feb 22, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
300 people viewed this question
Clive
Clive
old marine
old marine
