Question about Apple iPhone 3G
Iphone will not sync with itunes - Apple iPhone 3G
  • Apple Master
  • 4,338 Answers
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Sep 12, 2009
I am having problems with my iphone 3g. I cant access itunes with my usb lead it is not working and does'nt recognised. I can use the charger to charge my phone. 'very strange'.
I hope that someone can be a helpful to me on this occassion.
if you can solve this problem i will really be appreciated.
Ahmed
Posted on Aug 26, 2010
  • 502 Answers
Does it sync with your computer at least? do you get the usb device connected message? If not, does it do so with other computers? If both of the above is not true, There may be a physical issue with your dock connector or logic board. You can get the part at iPhone Repair and there is a guide that shows you how to put in the part at iPhone Repair Guide.
Posted on Apr 14, 2011
5 Suggested Answers
  • 4 Answers
SOURCE: My iphone is not detected by itunes
Put your iphone in the recovery mode and get out by ibrickr v9.*
Posted on Dec 27, 2008
no_pc-gst
  • 58 Answers
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Posted on Jan 02, 2009
SOURCE: Error code #13019 iphone not syncing w/itunes
I googled this question and found out a lot of people are having this problem. Check this thread out for the solution. It worked for me.
http://support.apple.com/kb/TS2830
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: i can't find sync in itunes ,can't sync iphone
If Solution #1 won't work, try the following:
Download and install ifunbox, then use it to find the file iTunesDB in your iPhone.
Delete the iTunesDB, and the problem should be solved.
Posted on May 27, 2010
How to copy my ringtones from iPhone 6s to iPhone 7 Plus?
When you want to transfer ringtones from old iPhone to new iPhone, you will come up with the sync problem when using iTunes. iTunes provides a "Transfer Purchases" function for the you to transfer purchased items back to iTunes library, but the customized ringtones cannot be transferred back. If you are not sure about how to use the "Transfer Purchases" function of iTunes, check out the following tutorial.
1. Start iTunes, and go to "Edit > Preference > Devices". Check "Prevent iPods, iPhones and iPads from syncing automatically".
connect iphone to itunes.
2. Connect your old iPhone to PC via USB cable, then double click on the iTunes icon to launch the iTunes app on your computer if it did not start automatically when your iPhone is connected to computer.
3. Click "File > Device > Transfer Purchases" at the upper corner. Then click "Apply" at the right bottom. iTunes will automatically sync the transferred items to iTunes library, and the purchased ringtones will be transferred back as well.
4. Then disconnect the old iPhone from computer. Connect your new iPhone to iTunes following the step 2. Click on your iPhone, click the "Tones" to open the ringtones tab. Check the box for "Sync Tones" and then check the boxes for the ringtones you want to sync. There are 2 options avaliable, check "All tones" to choose all the ringtone files to sync, or check "Selected tones" to select the specified ringtones that you want to transfer. Finally click "Sync" button in the bottom right corner of iTunes, it will start transferring ringtones from iPhone to iPhone via iTunes. The synced ringtone files will appear on your iPhone as a ringtone automatically.
If you want transfer customized ringtones between 2 iPhones, you may need a 3rd party tool on your computer. Feel free to read the following tutorial for details.
How to Transfer Ringtones from iPhone to iPhone
Nov 07, 2016 | Cell Phones
How do i sync my iphone to apple itunes
try for these steps :
connect your iPhone to iTunes .
on the computer select your iPhone.
click music> syn Movies
click option> syn option for any other
click apply to sync your iPhone at lower right bottom.
For more help https://www.apple.com/support/iphone/syncing/
and need any technical help Mac Tech Support .
Jun 24, 2014 | Apple iPhone 3G
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
How do i download songs from my pc itunes to my iphone 4
There are 2 ways,
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
Nov 21, 2010 | Apple iPhone 3G
How can i put music on my iphone using itunes
1. Open iTunes. Open the Edit menu on Windows or the iTunes menu on a Mac. Click the "Preferences" option. Make sure the "Disable automatic syncing for all iPhones" check box is selected.
2. Plug your iPhone into the computer and wait for iTunes to recognize it. Click on your iPhone's icon on the right side of the iTunes window. Click the "Music" tab.
3. Select the music you want to sync to your iPhone using playlists. You can also select the option to sync all your music to the iPhone.
4.Click "Sync" when you're done customizing your settings.
Get more details: Transfer music files from Mac to iPhone
Nov 05, 2009 | Apple iPhone Smartphone
How do you remove synced photos from the iphone?
You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
Hope that helps!
Oct 30, 2009 | Apple iPhone 3G
Sync iphone to outlook contacts
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts. sync-iphone-outlook-contacts-oxaxc0rwhkhzilrwacqreyis-3-0.jpg
  1. Connect iPhone to computer with USB cable, and launch iTunes.
  2. Click iPhone icon, and choose Info the Summary Panel in left sidebar.
  3. Check Sync Contacts with, and choose in the drop-down menu.
  4. Click Apply at the right bottom to start syncing iPhone contacts with Outlook.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
Jul 19, 2009 | Apple iPhone Smartphone
How to load itune in my iphone?
iTunes does not load to your phone. iTunes is the program that syncs your music over to the iPhone. You have to download iTuens on to your computer, then sync the iPhone with the USB cable.
See this link:
Download the latest iTunes to your computer :
http://www.apple.com/itunes/download/
Set up iTunes syncing:
  1. Connect iPhone to your computer, and open iTunes (if it doesn’t open automatically).
  2. In iTunes, select iPhone in the sidebar.
  3. Configure the sync settings in each of the settings panes.
  4. Click Apply in the lower-right corner of the screen.
    By default, “Automatically sync when this iPhone is connected” is selected
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | Apple iPhone 3G
How to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
Apple iPhone 3G Logo
24,194 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
