Question about Air Tools & Compressors
Howdy, I just acquired an air compressor, ''Westinghouse Air Brake Co., Type Y 3YC, SN 136848. I am wondering about parts motor config, cfm output, psi, etc. It appears to be a 2 stage & I'm thinking it should reach 175 psi or so. Can you assist in the matter? Thanks LT
We have a Westinghouse 3YC air compressor. The safety relief valve in the line between the two compressors started "popping off" recently. The compressor seems to be working fine. Is this a problem only with the relief valve or could there be a symptom of a more serious condition that we should be attending to? The valve is stamped 60 max which I assume is 60 psi. Is this the correct size. The tank pressure is set for125 psi. The tank relief valve is marked 250 max.
Posted on Sep 25, 2011
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I have a very old Westinghouse Air Brake 1BYC, Type Y, maybe model # 209878, air compressor. It is very slow to even pump 80 psi and then the pressure will leak completely to zero. I think wear of the...
If there is no external leakage, then air is probably slipping back past the valves. If the cylinders and rings are good, a valve change may fix it. There are still aftermarket parts available for these machines. As a rule of thumb, a rebuild with rings, gaskets, valves, and bearings usually runs about $100 per horsepower.
Apr 09, 2011 | Air Tools & Compressors
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Nail Gun how to
One of the factors used to designate compressor power is motor horsepower. However, this isn't the best indicator. You really need to know the amount of air the compressor can deliver at a specific pressure. The rate at which a compressor can deliver a volume of air is noted in cubic feet per minute (cfm). Because atmospheric pressure plays a role in how fast air moves into the cylinder, cfm will vary with atmospheric pressure. It also varies with the temperature and humidity of the air. To set an even playing field, makers calculate standard cubic feet per minute (scfm) as cfm at sea level with 68 degrees F air at 36% relative humidity. Scfm ratings are given at a specific pressure–3.0 scfm at 90 psi, for example. If you reduce pressure, scfm goes up, and vice versa. You also may run across a rating called displacement cfm. This figure is the product of cylinder displacement and motor rpm. In comparison with scfm, it provides an index of compressor pump efficiency. The cfm and psi ratings are important because they indicate the tools that a particular compressor can drive. When choosing a compressor, make sure it can supply the amount of air and the pressure that your tools need.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Portable Air Compressor Comparison
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
Aug 27, 2008 | Acme Automotive ACMA680CS Typhoon High...
Air Tools & Compressors Logo
566 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
