Question about Refrigerators
Not getting cold air into refrigerator, but the freezer is cold. Found ice blockage in the vent, why?
  • 59 Answers
MAYBE UR DRAIN HOSE CLOGGED,NOT DRAING PROPERLY SO HAS NOWHERE TO GO SO IT FREEZES.THIS CAUSE THE BAFFLE TO GET CLOGGED W/ ICE
Posted on Sep 12, 2009
Model bc121v1w refrigerator not getting cold
Is the freezer still freezing? If it is there is probably an ice blockage at the rear of the freezer compartment in the vent that takes cold air to the upper refrigerator You can defrost the whole thing and restart or remove the back panel of the freezer and defrost the air vent which is directly behind the fan . You will probably have to remove the ice maker which is not hard, then just get a blow dryer and defrost. If your freezer is not cold you have a different problem. If this fixes your problem but it happens again in a week or two either your defrost circut is gone or you have a air leak in the freezer compartment arond the door seal and you are letting too much moist air into the freezer compartment
Nov 02, 2013 | Amana ABB1927DE Bottom Freezer...
Refrigerator is warm. found ice packed in vents on frig side cleaned them out but now we noticed that the vents in the back of freezer are also packed with frozen ice build up. could this be the reason for...
That ice is the reason that the freezer is working but the refrigerator is not cooling. That ice is
blocking the vent that allows cool air to leave the freezer section andfall down into the refrigerator
section.
The fix is free: defrost the frig - pull the plug, and let that icce melt out of there, clean up the
wet mess, and turn the frig back on - problem solved.
Keep the vent area free of ice (and other blockages, like frozen peas covering over the vent), and
you'll keep the problem from recurring.
Aug 08, 2011 | Refrigerators
My refrigerator model is FRT8S6ESB8, it's frost free. But now have a problem. It is too cold in the freezer (have ice and frost) and is not cooling in fridge.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Frigidaire Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
My Maytag wide-by-side refrigerator -- problem with the refrigerator side not being cold, but the freezer side is cold...What do you think needs to be fixed on the "refrigerator" side? Many thanks.
check the vents that separate the two refrigerator sides for good air flow: (no blockage, dead fan etc.) as there is only one compressor circulating freon coolant gas through both sides; cooling temperature is acheived by adjusting air flow vents (the cold control usually is not at fault.)
Apr 05, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Refrig does not keep cold
Sounds like vents may be plugged.. Unplug and open doors. .Completely defrost and check vents between freezer and fridge for blockage.
Jul 06, 2009 | Refrigerators
Frezer cold ref is not
The refrigerator gets cold air from the freezer. There is a small vent in which cold air make its way to the refrigerator from the freezer. make sure that vent is not blocked by ice or something.
Jun 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Jun 22, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
