What causes Viewsonic VX910 to go to black screen one second after power ON?
    Scholar:
  • 53 Answers
Depends of front LED behavior: if it turns off as well then power supply gets overloaded, if it stays on then inverter turns into protecting mode.
In first case check for suspicious looking electrolytic capacitors over power supply module.
In second case you may need to check backlight lamps, driver MOSFETs in the inverter (if PCB around and under them is darkened, better replace them). More unusual problem is faulty high-voltage capacitors in secondaries of pulse transformers, or damaged insulation of high-voltage wires from inverter to lamps.
Please ask if you need you need more specific info about MOSFETs or lamps replacement.
Posted on Sep 12, 2009
I have a ViewSonic VX910 LCD monitor. I turn it on and it comes on for a second then goes black. I did replaced all five capacitors in the power supply board, but it didn't help, still the same problem....
AllI can think of is that a tripler or inverter could be breaking down, causing the unit to go into auto
shutdown mode. Some devise is breaking down, and causing the unit to shut down.
Not an easy problem to troubleshoot unless you've got a schematic and tech skills.
Hope this helps
Mar 26, 2011 | ViewSonic VX910 19" LCD Monitor
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
I turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 16, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
My screen turned black and began flashing.
Kim, The LCD display requires WHITE light so you can see all the colors on the screen. Most BLACK screen problems will be a power supply problem internal to the monitor. I monitor is still under warranty, have Viewsonic repair it. Here are a few more options that could be available if unit is out of warranty. 1. Trade in for new widescreen display. Please note that the electronics technician at the store will evaluate your monitor and try to repair it for less than $10 in parts! He or she will keep it as a spare unit or sell your monitor for $40 - $60 to a buddy that needs a spare or second monitor. 2. Check to see if Viewsonic has a CASH+old unit swap-out program. They ship you a REFURBISHED same model unit w/ 30day warranty. Yes! They will REFURBISH your old monitor and ship it to another customer. But that's only if a swap program is in effect! 3. Check with a local TV/LCD monitor repair shop, to see if they refurbish LCD monitors with new or rebuilt "switch-mode-power-supply" / "inverter supply" / "cold-cathode-fluoiescent-lamps" . 4. Most costly option. Buy new display AND have your VX910 repaired and kept as spare unit! Before you do any of the above mentioned options visit (FYI) YOUTUBE and search for and view the longer (8-12 minute) video clips of "LCD monitor repair" and "LCD monitor disassembly" to learn what the most common causes of LCD BLACK SCREEN failure are and what parts are used to fix them. Also visit www.ccl-la.com/badcaps.htm and www.lcdparts.com , www.badcaps.net for more information. If your VX910 falls into the FAILED CCFL backlight catagory get back here to fixya and let us know what option you will persue. If this was helpful to you or someone else, rate this response on fixya. 12fixlouie by for now.
Nov 04, 2009 | ViewSonic VX910 19" LCD Monitor
Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Nov 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
The problems is my monitor (VeiwSonic VX910) is blinking evey few seconds from destktop screen to black screen. help!!!
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
BER-2 Number: D9 SCRAP NOT AUTHORIZED
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Jan 08, 2008 | ViewSonic VX910 19" LCD Monitor
LCD monitor problems.
Hi.
If the monitors use seperate plug in power supply EG 12 to 24volts it could be that at fault.
Or it could be the invertor at fault.
I have had some success repairing invertors if you can use A meter remove invertor Panels & check accross the coils with meter set to ohms all the coils should read identical chances are you will find one set of windings either dead short or open circuit. This will be the faulty coil hopefully as your monitors are all the same make the coils will be the same.
Carefully desolder faulty coil & fit one that reads good from a doner board.
Look for any SMD type fuses & check or replace them & thats it I have done quite a few now using this method.
Give it a go.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | ViewSonic VX910 19" LCD Monitor
Viewsonic vx 910
it is power problem pls show it service personnel
Sep 21, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
