Question about Lexmark X3470 All-In-One InkJet Printer
My lexmark x3470 printer says cover open when it is turned on.
I have to unplug to turn it off the off switch doesnt work. Can someone help me.
Our lexmark 5400 series printer fell on the floor. We put it back together but now it says cover open even when it's not. Not sure how to fix this problem.
Try to remove the sheets of paper from the feeder. Open the cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges and make sure they are properly seated and secured. Close the cover. Load some paper. Try to print again. If problem continues, please contact Lexmark technical support for additional assistance.
May 03, 2011 | Lexmark X3470 All-In-One InkJet Printer
Open cover problem
You have go to service, becouse the switch for cover is brouken, and they need put them ih close mode. In same primter model switch is in diferent placeses
Sep 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Try looking around the edges of the cover or in the hinge area for a switch that may be stuck. Most covers have a switch to indicate that the cover is open, the cover may not be seated properly or the switch may be stuck in the open position.
Aug 30, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 has cover open in display will not do anything now
you need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
Sep 29, 2008 | Lexmark MFP-X3470 All-In-One InkJet...
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
Please do not forget to rate my solution
Thank You
Jayson
Sep 09, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Aug 12, 2008 | Lexmark X3470 All-In-One InkJet Printer
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
