Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Noise in the spin cycle
By warnockppwar on Sep 12, 2009
noise in the spin cycle
Solution #1
posted on Sep 12, 2009
Not Rated)
GodBlessU
Rank: Guru  Washers & Dryers  Expert
Rating: 85%, 160 votes
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
Washer fills with water then runs thru the cylce and then the water drains but the drum is not... (More)
Answer
I have a Kenmore Elite (Calypso washer machine) and try to run the empty cycle to clean inside. What... (More)
Answer
the agitator on my hotpoint washer seems quite loose and makes a knocking noise,can it be tightened?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
