Question about Uniden DECT 6.0 Cordless Phone ID
How do I set answering machine to pick up after five rings instead of two?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden system I can only suggest that you select it from the list beginning here to download a copy of the manual. You may have to settle for either four or six instead of five.
Posted on Apr 28, 2012
kibbs
  • 234 Answers
SOURCE: The Answering Machine won't pick up, phone just rings
the cordless phone was working in power and inbuild batteries. answering machine is not like that. It does not have inbuild batteries! keep seperate batteries for answering machine OR otherwise keep UPS.
thank you...........
Posted on Jun 17, 2008
cnavarro
  • 2460 Answers
SOURCE: How to set the number of rings before the machin answers
Log into your Vonage account and change the number of rings or seconds to intercept for VM. In my Packet8 service, I can set a number of parameters for dual ring, intercept, and/or turn voice mail on and off. The last time I worked on a customer's Vonage we could do the same.
Carl
Posted on Feb 11, 2009
homedesigner
  • 583 Answers
SOURCE: how do you set number of rings before answering
On the side of the base unit there is a switch (looking at the unit, it is the right side). The switch has 3 positions, 2/4/TS. 2 means the unit will answer after 2 rings, 4 after 4 rings, and TS (toll saver) means it will answer after 4 rings if it has no messages waiting and 2 if it does.
The owner's manual can be located at this link - http://www.uniden.com/pdf/EXAI985HSom.pdf
Posted on Feb 22, 2010
BillB-SA
  • 2761 Answers
SOURCE: How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Posted on Mar 04, 2010
SOURCE: Answering machine is not answering
Check if all chords are plugged in.
Posted on Mar 16, 2011
I can send a fax without any problem, but am not able to receive. I have set it to send after 3 rings, but the phone rings and then my answering machine comes on. I just turned my answering machine off. ...
Set the answering machine to answer incoming calls before the printer does. For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls after five or six rings. Also, make sure the fax line is plugged into the Line port on the back of the printer and the fax settings are correct (phone number, pick-up on rings, etc).
May 12, 2011 | Lexmark X5075 InkJet Printer
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
I have my own voicemail service . How to i use that instead of the answering machine that is provided with phone
SET THR VOICEMAIL TO PICK UP BEFORE THE ANSWERING MACHINE.
EXAMPLE: VIOCEMAIL 3 RINGS, ANS. MACHINE 5 RINGS
Dec 11, 2010 | Uniden Lands Phones
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Brother MFC-210c printer
Check the basic settings for your printer to see if they offer 'manual' pickup of the line instead of only the number of rings. I've had the same problem years ago and had to set the fax machine for 6 rings, answering machine for 4 to allow me time to pick up the phone in case I was present. You should be able to find complementary settings with your two devices.
Sep 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Answering machine not working
change how many rings your voicemail picks up in or cancel it.
set your answering machine to less rings than your voicemail.
Aug 29, 2007 | GE Telephone pr521w
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
