Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42. No picture/sound.
Have an RCA HD61LPW42, is DLP. Press power, hear it wind up (hi pitched sound) then spins back down, no picture, no sound.
TV stays on 30 seconds and turns itself off every time i turn it on
Posted on Jun 30, 2010
  • RCA Master
  • 8,457 Answers
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Posted on Sep 12, 2009
My HD61LPW42 makes a high pitched wirring noise after it is on a few seconds sounds like the fan is rubbing against something but doesn't appear to be. The picture quality is still good and the tv...
this might be a noisy color wheel . this is a motorized wheel that produces the color in the set. it could be something else because of your statement of picture is ok. if it the color wheel the set will eventally shut down. this part used to be avalible and fairly easy to replace. it has got harder to locate. The other possibilites includes a small leaky capacitor in the powers supply but that is more like a whine. a tech would have to take the back off and locate the noise.. i believe this unit might have 2 fans and a color wheel. three moving motors.. anything that moves eventally dosnt
Mar 22, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Picture occasionally goes out, still have sound when this occurs and then the picture will come back on after a while. When the picture is out the lamp is off. Hd61lpw42 RCA DLP TV
Souns like the Lamp is going out ,If you have never replaced Lamp then that is what your Problem is Mats has them for $99.00 1-800-628-1118
Nov 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have an RCA Scenium DLP 50 TV. The TV started making a loud noise (like a computer fan) going out. The noise would go away when we powered off the unit and the bulb shut off. Eventually there was no...
yes ... you could have a color wheel problem.. this set get color from a spinning wheel called a color wheel.. when you unplug this and plug this back in you should hear a whining motor sound. During the "bootup" sequence this motor spins this wheel to test to see if it reaches speed. This is a motor that moves and anything that moves eventally dos not. i see this problem often in the shop and if it is the problem there not all that difficult repair. the hardest part is finding the color wheel
Oct 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Install new lamp, nothing comes on ,change back to old lamp still nothing
Hi,If the lamp didn't do the work it could be that the problem is with something else.If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Do you hear buzzing or high pitch sounds? If you do it could be a problem with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Make sure the door cover is properly shut other wise it wont lamp light up.
Apr 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
703 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
