Question about GE Spacemaker JVM1640SJ Microwave Oven
How do you install a charcoal filter in a ge spacemaker microwave? we have the grill off and the door open and it seems to not fit. I checked to see if it is the right one and it is. Is there a trick I'm missing? wb02x10943
  • GE Master
  • 9,047 Answers
The owner's manual will give you the procedure for your model.
You can download GE owner's manuals and installation instructions here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/p126566-ge_spacemaker_jvm1640sj_microwave_oven/solutions
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
  • Shawn Butt Jan 21, 2013
    Thanks William, your link to the Solution at:http://www.fixya.com/support/p126566-ge_... really helped us. You're the best!
Where do you install the charcoal filter on spacemaker microwave oven model # jvm1540
remove the two and 3 maybe in the air grill at top of oven . behind inthe center is the filter . ( very pricey // about 60.00 / the make sure it seated properly so the air flow is through filter .. replace front grill and your done .. ****
Jan 09, 2010 | GE Spacemaker JVM1540 Microwave Oven
How to install charcoal filter in ge spacemaker microwave
top of the front grill there are 2 screws. remove those together with the grill. install filter in location underneath.
Dec 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The Charcoal Filter (JX81C) used for non-vented GE Spacemaker over the stove microwave (JVM1540SM2SS) does not fit anywhere (after pulling off the grill).
This of course assumes that your oven has the optional Recirculating Charcoal Filter Kit (part # JX81C available here) already installed.
From the owner's manual here:
Nov 27, 2009 | GE Spacemaker JVM1540 Microwave Oven
Message to change filter but unit exhaust up to stack?
Grease filters change from the bottom side of the unit.
Charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE XL1800 1100 Watts Microwave Oven
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
pull the plug.
oven and remove it.
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I can not locate my charcoal filter in my GE Spacemaker Profile JMV2070BH02 where is the charcoal filter
Charcoal filter is behind the grille at the top of the oven. Find screws in front or at top of the grille and remove them.  Remove the grille by shifting to one side and pulling forward with the door open.  You should see a slot where the filter is inserted.  Remove old filter and replace with new.  Note which side of old filter is up and position the new one the same way.  The filter sits on tabs at the side and back.   Replace grille and screws.
Jun 02, 2009 | GE JVM1440 Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to install charcoal filter in ge microwave md# jvm1870 sk04
From the owner's manual, page 37:
To remove the charcoal filter, disconnect power at the main fuse or circuit breaker panel or pull
the plug.
Remove the top grille by removing the screws on top of the grille that hold it in place and sliding the
grille to the left (opening the door makes grille removal easier). Slide the filter towards the front of the oven and remove it.
You can order new filters by entering your full model number here.
Sep 19, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
564 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
