Question about Refrigerators
Hello, I have a problem with an LG fridge GRS392GCA. temperature inside the machine raises after a few hours. I discovered that the coil was totally surrounded by frost. I heated the frost. the fridge works now but frost seems to appear again around the coil. Would replacing this element :''LG Refrigerator Defrost Control Assembly'' http://www.espares.co.uk/part/fridges-and-freezers/lg/p/1084/81/0/0/639711/refrigerator-defrost-cont.html solve the pb ? what other elements of the defrost mechanism could need replacement and could they be replaced by a non professional person ? Thank you in advance
  • sam_salman Sep 12, 2009
    hi,
    Thank you for your reply.
    The controller you mentioned, which one is it on among the following images http://samfridgetemp.blogspot.com/
    number 3, 4 or is it 5 ?
    if it's the last one, it doesnt seem to be easy to remove ! can it be done by a non pro ?
    thank you in advance.
  • 93 Answers
Usually it is not the heater but the controller for the defrost.
Which is a plastic package on the side if the coil, plugged into the roof.
Replace it, they are not expensive and testing one is.
Posted on Sep 12, 2009
Testimonial: "Ok, thank you very much. i will replace it."
  • ECHUCAELECT Sep 13, 2009
    usually it is not the heater but the controller for the defrost.
    Which is a plastic package on the side if the coil, plugged into the roof. its held in place with a plastic tie-cut it to remove the package.
    Replace it in the same position , they are not expensive and testing one is.
    part number is 6615jb2002t about $au6- $au10
My Kenmore 106.58909802 is freezing the food in the fridge and the water line is frozen too. any ideas?
Turn up the thermostat a bit and place a fridge thermometer inside to monitor the temperature.
Pull the fridge away from the wall and vacuum the coils, and underneath. Leave it away for a few hours.
Hope this helps.
Mar 03, 2015 | Kenmore Refrigerators
Danby upright freezer plugged in a few hours ago, but coils on back are hot
If you are talking about the black condenser coli on the back of the fridge it is hot because the refrigerant is pulling all of the heat out of the fridge and trying to deposit it outside of the box. This is called hot box pull down. When the temperature inside the fridge comes down and you have product in it the coil on the back will become much cooler during operation. So if you are wondering it is nothing to be worried about, perfectly normal.
Aug 29, 2014 | Danby 10.4 cu. ft. / 294 liter Upright...
Refrigerator/freezer not cooling. Model Number: 106.42102301.
Kenmore brand refrigerators offer energy efficiency and space saving benefits with a range of innovative designs. The company's refrigerator-freezer units are manufactured in traditional top-mount freezers, bottom-mounts, and side-by-side styles. Occasionally, as with any brand of appliance, the components can malfunction and cause the freezer to stop working properly. A few troubleshooting steps can help locate the problem so that it can be repaired.
  1. Power Supply
    • Occasionally the power cord to your fridge slips out, or the outlet it's connected to is defective. Before troubleshooting other potential problems, check that your fridge is plugged in, and if it is, try plugging something else into the outlet to confirm that it is working. If there is no power, check the fuse or circuit breaker and replace or reset if necessary.
    Thermostat and Compressor
    • Freezers rely on the thermostat to know when to turn on the compressor and when to turn it off. Thus, the thermostat controls the temperature in your fridge. Typically, for a Kenmore refrigerator, the recommended setting for both the refrigerator and the freezer is 3. Check that both are set properly and if they are, try setting the freezer's thermostat to a slightly colder setting. The refrigerator's compressor should turn on. If you don't hear a fan turning inside, your thermostat or compressor may need to be replaced.
    Defrost Timer
    • The defrost timer regulates when the freezer and fridge will run its defrost cycle. If your fridge is not defrosting, or it is defrosting too often, this can affect its ability to freeze food. When in defrost mode, the freezer stops blowing cold air. Test the defrost timer by manually advancing the timer using a screwdriver inserted into the advancement pinion. Turn it clockwise for a 1/4 turn. This should force the timer to advance out of defrost in less than an hour. If it does not, you may have to replace the timer.
    Evaporator Coils
    • When the evaporator coils become frozen, your freezer will likely malfunction. If they are dirty or dusty, the same problem can occur. To defrost the coils inside, you can turn your freezer off for 24 to 48 hours then turn it back on. If it works properly, then the evaporator coils were frozen. Clean the coils located on the back of your fridge as well to ensure that dust and debris aren't affecting their efficiency.
    Wiring
    • The wiring outside and inside your fridge can be damaged by rodents or pets. Check the wiring outside your fridge for breaks. If there are none, you'll have to check all of the wiring. This is a long process requiring you to use a meter to test each connection. You may want to call an electrician to test the wiring to ensure that it is done properly.
    Environmental Factors
    • Once you've checked each component that runs your freezer and confirmed they are working correctly, consider that factors outside the freezer can affect its ability to freeze properly. The problem may be that the door is opened too often or for too long, allowing the cold air to escape and raising the temperature inside. Check the seal around your freezer door to ensure that it is getting a tight seal when closed and no gaps are allowing warm air inside. If you've added a significant amount of food all at once, this will increase the temperature inside and freezing can take several hours. If the vents are blocked by food items the movement of cold air is limited and will affect the freezer's temperature as well.
Hope this solution will help to solve your problem.
Good day! : )
Aug 30, 2011 | Kenmore Refrigerators
Freezer not freezing
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this would help you.
Have a nice day! : )
Aug 28, 2011 | Kenmore Refrigerators
Refrigerator & freezer not coolilng
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this will help you.
Aug 22, 2011 | Kenmore Refrigerators
Kenmore refrigerator 253.69962702 not cold. freezer frosting up.
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this tips will help you.
Have a good day! : )
Aug 20, 2011 | Refrigerators
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Burning smell and dead mini-fridge/kegerator
If the compressor is being used for extended times without resting or getting the product cooled, could be the problem. On small refrigerators the inside is sized for the work load. The condenser coil on back or in some cases under the outside skin of the refrigerator is designed to cool the area inside by releasing the heat from inside.. You may need to modify your cooler to handle such loads with more cooling capacity and condenser with fan to help bring the product temps down more efficiently. Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Sanyo SR-4912M
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
