Question about LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator
My LG French door refrigerator has a burning fishy odor (outside the refrigerator) and the power periodically cuts off. Once we unplug it and plug it back in the refrigerator comes back on. This refrigerator is 1 year old.
    New Friend:
Most likely the Ice Maker fan motor is blocked with ice and the fridge needs to thaw for 4 to 6 hours. There is also a good possibility that your ice maker fan motor is burning out. This needs to be addressed immediately before there is mother board damage.
Posted on May 23, 2014
    Champion:
  • 242 Answers
Filter needs changeing or blocked
Posted on Dec 23, 2009
How do I clean drip pan on LG French door refrigerator?
Does it not sit on top of the compressor? Behind the unit, at the base. Check for spilt milk, too.
Dec 21, 2014 | LG LFX31925SB
LG French door refrigerator bottom freezer not working
Check inside vents are clear and door seal is good. Check air compressor area is clean and well ventilated. Put setting in a low number and turn off / unplug unit, count to 10 and plug in, turn on.
Crossing fingers helps too ;)
Mar 30, 2014 | LG 7841 Bottom Freezer French Door...
SQD26VL side-by-side has a fishy odor. Where is drip pan?
The drip pan is outside the fridge I believe, sitting in the back panel.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
I just purchased a Samsung French Door Refrigerator...how do I get rid of the plastic odor?...I've put baking soda in the refrigerator and the freezer but the odor persists.
You can try activated charcoal to absorb the plastic odor. You'll find charcoal in the aquarium section of your ""big box" stores. Depending on how it's packaged, you might have to cut a **** in the package to expose the charcoal. You DO NOT want to use Barbecue charcoal! You can also wipe down the entire interior with a baking soda solution and then rinse.We had the same problem with our Samsung French Door and it was gone within a few days once we began filling it with food and leftovers!
I hope this helps. If it does, please come back to Fixya and rate my advice.
Aug 07, 2011 | Samsung Microwave Ovens
LG Model LFC23760 (French Doors, bottom freezer) power prob
Unplug fridge.
Open panel on back of fridge (the one at hip height that says Service Panel Only - Do Not Remove, blah blah blah)
See pictures here: http://www.amazon.com/LG-LFC23760SW-French-Refrigerator-White/dp/B00198A5C0/ref=cm_cmu_up_thanks_hdr
Replace fuse with 9A 250V slow-burn fuse. I used a gray fuse harness from Radio Shack so that if the fuse needs to be replaced again I can just pop in a new one without doing the soldering over.
I nuked the original fuse, the end-caps and the wires that went from the end-caps/fuse to the motherboard. I replace those wires with some I scavenged off a fresh thermal fuse (also bought at RS, just needed the wires themselves which seemed to be the same diameter/gauge as the original leads) and ran them from the motherboard to the wire harness.
So far, so good!
Good luck to you.
Jan 31, 2010 | LG LFC23760SW Side by Side Bottom Freezer...
DEFROST SENSOR is broken. bought the part and need help installing it
YOU NEED TO REMOVE THE BOTTOM DOOR, BASKET, ICEMAKER IF YOU HAVE ONE THEN THE BACK PANNEL PULLS OUT FROM THE CENTER AFTER THE COVER IS REMOVED YOU REMOVE THE SCREWS HOLDING THE INNER PANEL ON IF THERE IS ONE AND ONCE YOU SEE THE EVAPORATOR LOCATE THE SENSOR USUALLY ITS STRAPED TO THE EVAPORATOR, CUT THE STRAPS CAREFULLY THERE IS A LITTLE FINGER ON THE WIRE PLUG YOU NEED TO PUSH DOWN TO UNPLUG IT
Jan 13, 2010 | LG LRFD25850 French Door Refrigerator
Smelly Maytag
Does it smell like rotten food or what
Jul 11, 2009 | Refrigerators
Door open alarm will not shut off
Try pressing the cut off button manually while the door is open. It sounds like the switch may be bad.
May 13, 2009 | LG LFC22740 Bottom Freezer French Door...
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
247 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
