Question about Garden
The crank is very stiff and mower wont start, it has been sitting for about 4 years, i checked the oil, it was good, i added gas but no luck
  • 474 Answers
Pull the spark plug and spray some wd40 into the hole. then slowly pull the starter. repeat this until the engine pulls smooth. then pull the starter fast a few 10 times to get the excess oil out of the cylinder. reinstal plug and try again
Posted on Sep 12, 2009
John deere L100 cranked over...wouldn't start...out of gas....added gas, now wont crank over at all
Thou has drained the battery with all your cranking. Recharge unit and now check for spark since you have resolved the fuel delivery issue.
Mar 14, 2016 | John Deere Garden
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
Push mower starts, but then dies. I have checked gas and oil, and added fresh gas. Oil is clean. WHY WON'T IT STAY CRANKED?
carb could have an obstruction . gas in sediment bowl burns ,mower dies, wont start again until gas has trickled back in to fill bowl.
Oct 12, 2014 | Briggs & Stratton Garden
Scag tiger cat wont start
I would put new plugs in change the oil put a new in line gas filter in. After this tune-up check for spark by leaving the plug out on the moter body crank it over if the spark is hot you know its a gas problem also check for any grounding by starting it at night then looking around to the engine to see if its grounding out. Try these simple things. Do not change anything on the moter without doing these things first. Good luck
Apr 11, 2014 | Scag Tiger Cat 52 Zero Turn Mower...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
89 honda civic hatchback, car wont start
If your lazy... sounds like you might be in regards to this car than I would at least pull the plugs (inpect them for corrosion or damage and squirt oil in the cylinders not too much, you cant spin the engine after 4years without lubricating the motor. Than see if it combusts using starting fluid, it it does fire then address the fuel system and clean. Good Luck, I think you will be ok but 4 year old gas is like varnish...
Oct 24, 2009 | 1989 Honda Civic
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the carburator.here is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Husqvarna 65021 RS lawn mower, > 1 year old will not start
yea i think you scratched the cylinder. if there is not oil at any point then the engine will damage itself. and it wont have good compression. unless you want to attempt to rebuild the engine i would scrap it.
Apr 09, 2009 | Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
