Question about Digitrex Cameras
I install SD card and camera will not operate. Green lite indicates camera on. Works ok with SD card removed.
  • 1,606 Answers
There can be a problem with the SD card itself. A bad sd isn't common but they do happen. What I would check is that the sd card is compatible with the camera. It can be too big or the wrong type or the wrong speed. As a result the camera can't read the card and just sits there. Your camera manual should show a list of tested sd cards. If not your best bet is to go to a store and bring your camera and ask to try before you buy.
If you can read the sd card in something else then it is most likely compatibility problem. If it can't be read about all you can do is try to format the card and see if that brings it back to life.
Posted on Sep 12, 2009
Sd10 elph green
I suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries. you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
Oct 11, 2008 | Canon Cameras
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
WHEN I WENT TO SHUT IT OFF, A "FORMAT" OPTION CAME
1) Remove SD Card.
2) Remove Battery.
3) Hold power button for 10 seconds.
4) Install Battery.
5) Attempt to power on.
6) If works, reinstall SD Card and you're ready to go!
Thanks and please rate if this helps you!
Mar 29, 2011 | Vivitar ViviCam 8025 Digital Camera
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
Magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...877f33f.jpg
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
Jun 02, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Nikon P4 all Photo's are "green"
try getting a new SD card and transfer the old photos to the new SD card
Sep 17, 2008 | Nikon COOLPIX P4 Digital Camera
Format problem
Check if the SD card seems to insert properly. If not, the pins could be crushed in the SD card holder. That's what happend to my camera. So the camera will work fine without an SD card but I can't install a card. The other possiblility is that the card is incompatiable, but if the card was working before (and not in the locked position) that's not the issue.
May 01, 2008 | Cameras
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Cameras Logo
53 people viewed this question
Top Digitrex Cameras Experts
Vladimir Frolov
Tony Parsons
Tony Parsons
Mirela
Are you a Digitrex Camera Expert? Answer questions, earn points and help others
