Question about Maytag Neptune MAH5500B Front Load Washer
My washer runs fine until it has about 15min left. It then goes on pause, with Lr code showing. When I push the start button it will restart but never completes the cycle.
    President:
  • 1,776 Answers
The Lr code is a lock rotor error. This is not great news. You can do some electrical troubleshootingMy washer runs fine until it has about 15min left. - 2.gif and look for burnt or damaged wiring. This problem is sometimes, but not always accompanied by a burnt fuse. The wiring harness can be checked for any indication of a short in the wiring somewhere, but Maytag had some issues with this machine. It generally means that a new motor and control board are in your future. Sorry to say that, but Maytag upgraded the motor and control board because the problem was so prevalent a few years back. Hope that I'm wrong, but there it is. I have heard of a bad ground at the water inlet valve causing this code and it can be checked out, but given the history of this particular machine, I am not confident that this is the problem, but it is worth checking out. Anyway, I am sorry for the problem you are having and hope that this helped. Best wishes.
Posted on Sep 12, 2009
    New Friend:
I see a green ground wire loose. I dont know where to place the other end of wire?
Posted on Aug 04, 2013
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Washer gets to rinse cycle and starts to pump water then stops?
Before hitting any buttons you need to write down the fault code. As soon as it starts beeping take note of which lights are on along the top row. There are 8 lights. Count from the right and tell us which number light is on and which are off. That will tell us the error code and what it means.
May 30, 2017 | Fisher and Paykel GWL11 Top Load Washer
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
What does the code Lr mean at the end of the cycle and door remains locked
According to the manual Lr means 'Motor not running properly' and it says you should call for service.
You may be able to open the door by pressing the start/pause button and waiting for a minute or so.
Mar 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Car restarts after automatic shut off
When you use your remote start system the vehicle will run aprox. 15min. ( depends on your settings,check your manual) But will go thru a cycle and shut it self off and then restart the vehicle again until you either push the remote stop button,depress the brake,open the hood or insert the key.
Dec 27, 2009 | Python Vehicle Parts & Accessories
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
