Question about Panasonic Audio Players & Recorders
My monster ht700 surge protector will not stop beeping.
Had a storm, tv and cable shut down and the surge protector started to beep. Turned it off but now I can not stop it from beeping - I dont 'know how to reset it even after pushing the reset button.
SOURCE: Push Power Protector
I had the same. It was caused by the speaking wire ends touching the unit. I was just setting it up and had not fully connected everything. They were just loose. In general i think the message is trying to say check the power or check all your cables for short circuts.
Posted on Feb 17, 2008
SOURCE: Pushing Start Button only results in "Beep, beep, beep"
Actually, what appears to have happened is that somehow the door locked while it was open. I've ordered the door latch mechanism and the repairman is coming as soon as the part arrives. Good thing too. The seal around the inside of the drum was torn in places and leaking water. We've ordered that too. Thanks for all your suggestions. By the way - there was no error code at all. Hopefully this will all help someone else.
Posted on Mar 18, 2008
  • 10 Answers
SOURCE: reseting my surge protector
What is the model of your battery back up? When does it beep? What kind of beeps?
Posted on Nov 18, 2008
SOURCE: panasonic sa-ht700
Usually problems that start "out of the blue" after being powered-up for hours, caused by heat building up are due to things inside getting hotter and hotter until they fail. Unless something actually burns up, this is a reversible problem. Shut it down to allow it to cool off, and it works again. I own a SA-HT700. After 24 hours or so of being powered-on. it starts making a loud rumbling noise. Turning it off for 20 minutes fixes the problem. There's a fan on the back of the unit. It does not work. The heat sinks inside my unit are not covered with dust - suggesting the fan has never worked. I rigged an external DC supply to the 12V fan, so now the fan runs all the time. I am waiting to see if this fixes the problem.
Posted on Nov 20, 2008
welcomejee
  • 10594 Answers
SOURCE: Protector and "push Power"
Please check speaker wires should be properly connected and not touched / shorted.
Push Power Protect is error sign when unit got problem in Power Amp area and mostly its Power Amp Out IC failure.
I would suggest to ask Sony for warranty cover.
Posted on Nov 30, 2008
We had a power surge and know it's beeping
It did it's job and sacrificed it's self. There might be reset switch.
Jul 08, 2014 | Monster Cable HT700 Home Theater...
How do i stop lightning from getting in my hdmi lines and shocking my tv? 5 tvs went down in one storm
I would recommend getting a surge protector and using that to protect your televisions. This usually will stop something the lightning from killing your tv's.. I have a surge protector and can still use my tv, computer, anything I have plugged in during a storm.
Oct 22, 2012 | Vizio 42 in. LCD TV
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
My Monster Power HT700 will not stop beeping?
You have too many things plugged into it that require too much power. The Monster Power HT700 can not handle the pass-thru requirements needed to power your equipment. This beep is a warning that you are over drawing the Monster system.
Please rate if this helped :)
Mar 18, 2011 | Televison & Video
I have the monster power power center av700. It just started beeping and everything went off. How do I reset this or fix problem? thank you
no one buy this mickey mouse product its a piece of ****. ive had two now (second one not by choice)and even if the smallest surge goes to it, it shuts down and beeps. the only thing good for this is for ur dog as a chew toy. F u monster power...
Oct 04, 2010 | Office Equipment & Supplies
Sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Jun 26, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hello i have a sony kf 50we610 which stopped working after a storm. I was told to take a look at the D1626 diode and also to try to jump the termal sensor. I don't want to be messing with things i...
Hello Question? was your tv plugged into a surge protector or just into the wall plug. If plugged into surge protector and stopped working you need to see if your surge insure's your product. I have a monster surge protector on all my electronics and it covers up to $25,000 you have to register and submit proper documentation. In the future if this can be fixed please invest in a good surge protector. if you just plugged into the wall plug. Something durning storms something inside tv could have gotten zapped and if YOU go inside to DIY {do it your self} that voids the warranty on your tv so you would have to contact a authorized tv repair and have them do a in home diagnostic on it and alot of them will be honest and let you know what you need. If it can or is worth being fixed and some offer discount for going through them for diagnostic But what is so cool. You can also use their info to get a 2nd opinion call the manufature and ask to speak with tech support and run that by them and see what they say. Then that way you will be at peace with whatever decision you make :)
Nov 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Red color slide on left side of 43UWX10B
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Aug 05, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Reset Surge Protector
You can fix it by doing this. but first you need to make sure you leave your house for at least 4 hours so you don't have to be hearing that frigging noise, IT CAN BE DONE! i fixed it.
my unit would start beeping as soon as I plug it in wall, and red light come on, the software is telling me the battery is unplugged
this is what i did in order.
1. unplug all cords, connected to the unit, and power cord to the wall.
2. hold the power button
3. still holding the power button, Connect it to wall. (red light would be on but no beep)
4. I watched TV for 6 hours, red light still flashing
5. disconnect from wall
6 connect back to wall
I heard the unit click one time and green light came on, is charging now....
Jan 27, 2008 | Computers & Internet
1,328 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
