Question about Janome Memory Craft 5700
How do I raise and lower the feed dog
I can't even find in the manual to raise and lower the feed dog. It does tell you on page 42 to be sure to lower it for embroidery. But, how. I'm really not as dumb as I sound. But, I sure feel like it. :-)
  • 2 more comments
  • eaglerun Dec 11, 2007
    I have a slide switch on the back side of the machine. When I slide it, it does nothing. Finally I removed the metal guide over the feed dog and lifted it with a screw driver. It will lower with the slide switch, but will not raise back to normal by using the slide switch. I wonder if something needs to be fixed.
    While I'm at it, can I use ribbon in the bobbin like I used to do with my Singers?
    Thanks
    Thanks so much for the reply. :-) It worked !!!! Now I can get the house cleaned really quick and finish these last 2 baby blankets for the grandkids :-) Thankfully I had the most embellished ones finished before this problem. In fact it is all the embroidery work that got me to this place. :-)
    I've had more help here than any other place I've searched or asked. Again, Thank You !!
    ginger
  • Rbalderrama Apr 17, 2008
    I am having the same problem, but I can't find ANYTHING that is like a button or anything that would raise or lower the feed dog. Any ideas?
  • murphych Jul 11, 2008
    What is the balance wheel? I found the switch to drop the feed, but now I cannot get it back up. Thanks.
    New Friend:
  • 3 Answers
If you look at the back of the machine you should see the button that will let you lower the feed dog. It looks like you slide the button one way to lower and then the other way to raise the feed dog.
To make it a bit easier just go to the following web site and move down to the pictures as there is one showing the back of the machine. The button would be on your right:
http://www.ebay.com/itm/JANOME-MEMORY-CRAFT-5700-SEWING-EMBROIDERY-MACHINE-QUILTING-TOO-ADDED-EXTRAS-/301088834718
Posted on Oct 12, 2014
fwadley
  • 482 Answers
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Posted on Dec 16, 2007
  • 106 Answers
SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
Posted on Mar 28, 2008
SOURCE: feed dog
don't know how i did it but it is working now. thanks anyway.
Posted on Apr 02, 2008
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
bargainbox
  • 1388 Answers
SOURCE: Bernina Activa 131: Feed Dogs won't come back up
Raise feeddogs with switch, then turn handwheel one full revolution to re-engage the gear......unless something is jammed, that should do it. Do you have your manual ?
Posted on Nov 30, 2008
Can you raise feed dogs on elna su
It may depend on your particular model, but the Elna SP manual indicates there is a darning and button plate which means the feed dogs do not raise or lower.
Page 36:
ELNA SP Manual Page 23
Here are some tutorial videos that may be helpful:
Elna SU 62C Basics
At about minute 34 of the video, he puts the plate cover over the feed dogs so it is doubtful that your machine is any different.
Feb 06, 2018 | Elna Sewing Machines
6235 singer ! How do I raise feed dogs ???
According to the manual, there is an accessory that covers the feed dogs. (Shown as an accessory on page 4.) So the feed dogs should not raise or lower other then during normal sewing action of moving the fabric.
Singer 6235 User Manual Page 24
Singer 6235 User Manual Page 6
Dec 27, 2016 | Singer Sewing Machines
I can not raise the feed dogs on my New Home Model SS2015 machine even when following instructions -- push lever in direction of arrow illustrated. Help! Thanks!!
On sewing machines, when you lower the feed dogs the machine lowers them immediately. However, when you RAISE them, you must turn the hand wheel TOWARDS you several times before you hear them click into place. ALWAYS turn the wheel towards you for anything.
Nov 09, 2015 | New Home Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
How do i raise the feed dogs on my singer 30215 machine
Slide of the the little table with the accessories in.There is a feed dog adjustment lever at the back of the machine. sliding the lever to the 2 filled in arrows pointing down, will lower them and the 2 filled in arrows pointing up will raise them. The feed dogs will not rise up if you do not turn the hand wheel manually, even if the lever is slid to the right.You must make a complete turn of the wheel to raise the feed dogs.
Best wishes.
Jun 29, 2014 | Euro-Pro Shark 9110 Sewing Machine
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
How do I raise and lower the feed dog on my singer 8280??
On your Singer, you don't actually raise / lower the feed dog. Instead you attach a "darning plate" (which should have come with the machine) which covers the feed dogs so they do not come in contact with the fabric. See a page from the owner's manual using this link within my web site: http://www.sewvac1.com/Singer3080_Feed_Drop.pdf
May 06, 2009 | Singer 8280 Mechanical Sewing Machine
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
2,451 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
