Question about Dell 922 All-In-One InkJet Printer
It won't allow me to send a fax, message that I need to istall but it's already installed
My brothers mfc270j will not send fax, what to do?
Why won't it send a fax? Do you have it configured to send a fax?
Do you have a telephone line connected to it so that it can send a fax?
Are you getting any error messages?
May 31, 2012 | Office Equipment & Supplies
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
I have a hp3050 laserjet . I can't seem to send
you need to install the full software solution, you can get it from www.hp.com, on newer operating systems, as Windows 7 this option is not available at all
Apr 06, 2010 | HP LaserJet 3050 All-In-One Printer
Do you need an extra phone line for a fax on your printer
it depends on what type of printer you have...i actually have an HP officejet j3500 series, it a fax, printer,scanner and copier in one.. when im using it for sending fax messages, i just dial the number where im sending it and it automatically faxes (phone keypad and handset is included)... and i use it as my printer too so its already connected to my pc..so easy to use...
but but but... i actually connected a separate phone line (our original phone from our provider) to the hp j3500 series cuz sometimes i need to speak first to thr person im sending fax before i send the message... i think that is for manual sending of fax...
so if you want to send manually (speaking first to the person before sending) a separate phone line is required (connected to ur fax)
but if u want autofax, then i dont think its necessary...
there u go...
visit this website to learn more.. hope this is useful
http://h10010.www1.hp.com/wwpc/sg/en/ho/WF05a/18972-18972-3328064-3328083-3328083-3440951.html
Sep 10, 2009 | Lexmark X2470 All-In-One InkJet Printer
Cannot fax with printer cartridge (Brother MFC 3100c)
Nice try, but it won't let you do it, will it?
Kind of frustrating, since you thought that way you might get around the cost of new cartridges, no? Here's the brother support site if you really want to delve into it. But I don't thin so.
You can, on the other hand, send a fax from your computer over the fax/modem, if the document you want to send is already in the system somehow. If you need to scan it in with that same printer you're probably out of luck. But if you have an installed fax modem and are hooked up to a phone line, you can use Word or the modem software to configure and send faxes.
Good luck. There's alway Kinkos, I guess.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 26, 2009 | Brother MFC 3100C All-In-One InkJet...
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
Problem sending & Receiving Fax Imageclass D880 Canon All in one printer
#0018 indicates there was a problem with dialing, but it should show for sending faxes only. Since you can neither send nor receive faxes, and are getting a message saying "no signal", make sure that the phone line is still securely connected to both the L (line) jack on the machine and the phone jack in the wall. If it is, plug another phone into the accessory jack on the machine, and check to see if you are getting a dial tone. It seems like the machine is not able to communicate through the phone line.
Oct 10, 2008 | Canon imageCLASS D880 All-In-One Laser...
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Aug 26, 2008 | Computers & Internet
I would like to use my epson stylus cx7800 to receive and send fax's. Can this be done. Please explain and instruct. Thanks. lstrat@telusplanet.net
If you are running Windows, and have a modem, you can use the Windows Fax Services which are built in.
You may not have it installed, as it's an optional component. Go to Control Pane/Add Remove programs. Select Windows Components on the left hand side. If Fax services is not checked, do so, and press OK. You may need your original Windows install CD to complete the task.
If you still need help with this, please respond to this message. If I have solved your problem, I would appreciate you rating this as "solved".
Good Luck
airoff
Jul 21, 2008 | Computers & Internet
Dell 922 All-In-One InkJet Printer Logo
78 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
