Question about Refrigerators
Broken Light Bulb
The light bulb broke inside the socket in my Admiral refridgerator. It had been in the refridgerator since 1993. How do I remove it?
  • cleosmom Dec 12, 2007
    There is nothing left of the bulb to grip with pliers.
Turn off power then firmly push the blunt end of a fresh carrot in the bulb base and turn. No kidding it usually will work.
Posted on Apr 06, 2008
  • 25 Answers
Unplug the refrigerator first.
Then, try removing carefully the base of the socket with a pair of long-nose plier.
Posted on Dec 10, 2007
  • Bob Binette Dec 15, 2007
    Those socket are very thin and can be teared by taking a small part of the socket (side) with the pliers and twisting the pliers. It should come off...
Zing Ear light switch for Hunter ceiling fan the bulbs broke off from the inside and left a part. Can I take needle nose pliers remove the inside where can I get this type of bulb. Thank You Diane
Hi
A celling fan bulb like this
http://www.hunterfan.com/Ceiling-Fans/Clarington?ModelNumber=52004
There are three ways to remove a bulb where the glass envelope for the bulb has separated from the base. I used two of them a week ago. I replaced about 6 broken bulbs in floor standard lamps in an airport lounge.
First way, and you don't have to be too unsure whether the power is off. Use a new bulb and push it against the old socket and use the new bulb to unscrew the old one.
Next way, use needle nose pliers with insulated handles, grip the edge of the broken socket and twist it inwards which will partially wrap the socket around the nose of the pliers and then unscrew.
Final way, and with this way, you must flip the breaker and verify that the fan does not turn and there is no power at the bulb using a tester. Insert a dinner knife into the socket and unscrew.
Nov 17, 2015 | Hunter Dryers
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How do I remove a broken light buld that is stuck in the socket?
Use needle nose pliers
Go inside the bulb & open the pliers
& push down & turn
Aug 25, 2014 | Cars & Trucks
Cooktop light socket needs replacing, bulb broke in it. Socket needs replacing.
make sure the light is off, better yet turn off the breaker
take a potato a little larger than the socket, cut it to size, whatever.. jam it into the broken bulb (carefully), this will allow you to grip the broken bulb safely. turn counter clockwise and whats left of the bulb should unscrew out.. works VERY well
Feb 15, 2013 | Microwave Ovens
1993 Honda CBR 1000 F tail lights not working
Hi, Anonymous tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Help rear brake light does not work CBR Forum Enthusiast forums for Honda...
How to CBR Brake Switch Fix
http://www.cbr1000f.org/data/downloads/honda_cbr1000f_93_service_manual.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1990 CBR1000F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 15, 2012 | 1993 Honda CBR 1000 F
Light bulb broke off in fan light how do I remove?
If the glass is broken and there are sharp pieces sticking out you can use the potato trick. Cut a small potato so you have a flat end, make sure the power to the fan light is turned off, and push the potato onto the broken remains. Then you can turn the potato to unscrew the base and just toss the whole thing in the trash. Wipe off the socket and you're set for a new bulb.
If the old bulb broke off clean so that only the base is left in the socket, you'll need to bend the edge of the base inward a little with a small screwdriver. Then grab the base with needle-nose pliers and unscrew it from the socket. Again be sure the power is off before working on the light.
Mar 15, 2010 | Hampton Bay 48670 Flemish Pewter Finish...
Changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Dispenser Light broken
you can just unplug the refrig and use a pair of needle noase pliers to remove the base then install a new bulb it can not be over 10watt a night lite one works great (7watt) this will be a better solution that dissably. the panel
Feb 20, 2008 | Refrigerators
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
