Question about Kitchen Ranges
Display won't come on. Perhaps due to power surge. Found a burnt semi conductor attached to a heat sink on the main power board. Has anyone seen this problem before. Is the problem isolated to the powere board or is this just a symptom of another problem. GE Monogram Trivection Oven model zet3038shss.
  • 4 more comments
  • genny577 Sep 12, 2009
    No the oven does not work at all and there is no buzzing noise. Their was a power supply failure. Afterwards the oven did not work at all. Looking in to the problem we found that there is proper voltage to the power supply circuit board in the oven. However, there is no 12 volt dc output. On the power supply board the semi conductor marked top247y was blown. I replaced this with a new one. When I powered up the oven the component failed once again. So, I believe this to be a symptom and not the cause. My question is where to go from here. Could this be a problem on the main power board or is it possible that the display could be causing this componet to fail? Thanks Keith
    Magnetron is not the problem.
    I am new to this board so I am not sure if you saw my reply to the first person I talked to. So, I am sending the additional info to you. (I apologize if you already saw this info.)
    Thanks for the reply.
    I see that there are two display boards and a main logic board. Are you talking about one of these when you say the control panel is bad. The main power board has the failed intergrated circuit which I can replace again. I am not sure which one to replace.
    Thanks
    I have some experience with electronic & appliance repair. However, not a professional. Insurance is not an option for me. So, I am going to try to fix this unit. Are your reffering to the high voltage diode in the magnatron circiut? If so, this could not be the case because this problem occurs with only the main power board and touch pad control powered up. Someone else said it is common for the control panel to fail on these units causing the main power board to fail. What are your thoughts on this?
    President:
  • Kitchen Ranges Master
  • 1,922 Answers
Have you had any type of surges as in lightning,power line, from power supplier or dirty power as in harmonics,distortion of A.C. wave forms this can cause heating and destruction of electronic equipment as in the ranges power board,if not I'd just replace the power board, but it wouldnt hurt to check the neutral connection in your homes main power panel and make sure there is a solid bonded connection everywhere out to the metering equipment from the power supplier
Posted on Sep 12, 2009
  • 612 Answers
Please remember that I am attempting to diagnose your appliance without being there and with little information.
normaly the fuse will burn out before an outside source of power surge will take anything out but not always. It very well could have been a surge. Although I suspect that it came from within. I would check the board EMI filter and the diode attached to the capacitor. One of these are most likely the culprit.
If you decide it was a power surge, I suggest that you call a good local appliance service company to come out and make the diagnoses. There is some paperwork they will have to fill out so to get your insurance company to cover it. I have to do this all the time and if they are not filled out correctly, the insurance company will not pay. If they cover it and the company fills the paper work out correctly, the insurance company normaly replaces the unit rather than pays to repair. This is due to a power surge not only puts parts out it also weakens parts therefore causing problems down the road.
Please rate solution
  • 11,896 Answers
Control panel is faulty. You can get one and a manual at repairclinic.com
It is quite common.
  • 10,865 Answers
It sounds like you have been hit with a power surge. There is no other explanation for a burnt semiconductor. The problem is most likely isolated but you won't know for sure until you replace the fried part or test each component separately..
If you are not into electronics and do not have test equipment you are best off to call a technician in to take a look see.
  • 10,515 Answers
Just wanted to have some more information :-
1. Is your oven working well ?
2. do you hear any buzzing noise?
3. Does it heat the food well?
Kindly back to me with all answers.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 12, 2009
    Thanks for your response!!
    I guess it might be Magnetron.
    Note - This might be Dangerous. Follow on your Own risk.
    http://www.gallawa.com/microtech/mag_tes...
    I am not positive about any of the options given by you.
    Let me know the update!!
    Thanks.
Fuse exploding when i turn it on
Fuses blow when there is an overload. Generally caused by semi-conductor in the power supply or in the main amp section. The most likely cause being a short-circuited device on the heat sink in the main amp section.
Aug 21, 2015 | Audio Players & Recorders
Teac ls-l800 not working , think blown fuse
1 AT fuse is a 1 amp fuse.
Fuses tend to blow when there's an overload, mostly caused by a faulty semi-conductor perhaps on the main power amp board.
Apr 14, 2013 | Audio Players & Recorders
RX9010v overload message on powerup
Check your speaker connections to see if anything is touching -shorting- If no difference you might have damaged a semi-conductor located on the main amp board, or on the heat sink.
Mar 28, 2013 | JVC Audio Players & Recorders
My technics integrated amplifier su-v85a blows the fuse everytime i turn it on.what can be the problem?
Fuses blow when there is an overload. Often caused by a short-circuted semi-conductor. I would go straight to the main amp board and suspect the devices on the heat sink.
Jan 21, 2013 | Audio Players & Recorders
Why does t4al fuse keep blowing?
Fuses blow when there is an overload. The most common cause is a short-circuited semi-conductor device. Frequently found on the large heat sink of the power amp section of the unit. Very often this will have blown due to bad speaker wires. With the two wires touching each other more often than not. Or simply connecting the wrong type of speakers to it.
Oct 13, 2011 | Denon AVR-2309CI 7.1 Channels Receiver
Roland KC-550 blows 500ma fuses in power supply for no appearent reason. Why does this happen and are fuses correct value?
Fuses blow when there is an overload. This is caused by a faulty part in either the power supply (such as transformer or any semi-conductor -diodes, rectifier, IC, transistors etc) or in the main amp stage - anything on the heat sink. The most common cause is a semi-conductor acting like it was just a piece of wire. A cause of an overload alsot is a speaker wire shorting, which blows out the transistors on the heat sink or whatever is on there, they in turn blow the fuse!
Whatever value fuses is put in will blow! The higher the rating however could cause something to get hot thus causing a fire, before they do go!
If the 500ma fuses where the originals marked on the end cap, then stick with them. Often it is writtten on the PC board too.
May 20, 2010 | Audio Players & Recorders
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
May 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
A small 2.5 amp fuse keeps blowing. It is located at the back of the unit just after the ac inlet
When a fuse blows suspect an overload in the power supply or power amp section.
For culprits in the power supply check the transformer, large capacitors, rectifier, voltage control semi-conductors, diodes.
In the amp section any semi-conductor on the heat-sink.
Semi-conductors - transistors and IC's are the biggest cause of fuse blowing. They become short-circuit acting like a piece of wire!
Because of this transistors and diodes are easy to spot with an Ohm Meter, as it will be like you have just touched the probes together.
Very often they have holes, or damage, or have burnt up with this kind of fault.
If it is a fault on the main amp section, check your speaker wiring as the + & - wires could have touched to cause it.
Apr 18, 2010 | Pioneer A509R Amplifier
Arnet A700C Box shut down - 14 volts leaving power board OK?
THERE ARE STEPS TO FOLLOW, TROUBLEING FAULTING, CONNECT A METER AVO AND SET IT ON AMPS IN SERIES WITH OUT PUT, OF A POWER SUPPLY, THIS SHOULD BE OPEN CIRCUIT, I MEAN CUT A POWER LINE INTO A LOAD. AFTER THAT START ISOLATING SEMI CONDUCTORS ONE BY ONE, SEMI CONDUCTORS ARE COMPONENTS LIKE, DIODES, IC AND TRANSISTORS. A FAULT WILL BE FOUND
Mar 27, 2009 | Televison & Video
Blue convergence will not move left or right
look at the convergance board it will be the one on the left there re two stk semi-conductors tward the back of the board. most likly one of them are bad but sometimes the soldering can be faulty. look for signs of cold solder if so just resolder and should be good if not also look for burnt resistors. it will be obvious finding the stk 's can be done by using google and just type in the stk # finding the resistors you might try calling panasonic to find the part #by telling them the location of the burnt resistor. good luck. mind you that the soldering of the stk (semi-conductors) you will want to use a heat sink on each terminal you solder otherwise you take a chance of burning the conductor befor you ever get to use it, if you have no exp. soldering i wouldnt sugest trying it !!!!
Oct 17, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
