Question about BOSS AUDIO SYSTEMS Boss Ns2 Noise Suppressor Pedal
How to set up with amp and distortion pedal
How to set up NS-2 Noise Suppressor with amp and distortion pedal
  • 62 Answers
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Posted on Sep 13, 2009
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I have NS-2 Noise Suppressor Pedal, this works fine but in some moment make a radio noise (hum) and the output signal comes down (like turns the volume to 0) ... I don't know what it is, I'm going to...
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
Aug 06, 2010 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Will this amp have metal distortion if i add a distortion pedal
The amp can accept most anything you can get out of a distortion pedal. If you play it too loud you can damage any amp.
I would HIGHLY recommend you either take your amp to the store where you are buying your pedal and try it with your guitar before buying.
ALSO don't forget to get a power adapter as the pedals "eat: batteries.
May 02, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My BOSS Distortion(DS-1) pedal buzzes whenever the distortion is up. I've changed the battery, outlet, and amp, but it continues to sound. I tried a different pedal, and it worked fine. How can I stop it...
This sounds like a broken ground wire or trace within the unit if an IDENTICAL pedal does not act the same AT THE SAME SETTINGS.
Sometimes a circuit trace gets broken on the board inside pedals and can cause this.
Since an identical pedal doesn't have the problem, service is required.
If you know electronics you can open the pedal and look for obvious problems.
HINT: Use a bright LED penlight to "candle" the circuit board to look for cracks.
Look for broken solder joints... this can take an experienced eye to spot.
A distortion pedal NORMALLY is very simple circuitry.
Nov 08, 2009 | Boss Music
Constant hum/buzz only when the distortion is turned up. Otherwise works fine. Already checked cables. Please help.
Distortion is a very HIGH gain operation and any hum on the input will be amplified many times.
Check your guitar AND input cable for ANY hum at all at high gain settings on the amp WITHOUT the pedal in line to assure that the source is not before the pedal.
ADDITIONAL cause could be a poor power adapter for the pedal or even a bad filter cap in the pedal.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
I don't know how to set my roland u-20 for using a hold pedal "Kurzweil". My hold pedal is new, but i can´t make it work.
The Roland requires a NORMALLY CLOSED contact and that usually cannot be changed.
You will need to reverse the contacts in your pedal to meet that requirement.
OFTEN the pedals have BOTH contacts and you just have to unsolder and move the wire to the opposite contact. This is a common problem
Oct 29, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Boss noise reduction pedal stopped working for no reason at all. worked fine the day before, went to use today no power at all. it is run from an adaptor so its not the battery, any clue?
The power jack on MANY of the pedals are weak and a yank sideways can damage the jack or the board it is mounted on.
ANOOTHER problem is using an adapter with the wrong size plug. SOME plugs have a larger diameter hole and will work intermittenly.
Oct 05, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
The treshold needs to be turned all the way up in order to reduce noise..i thought that i must be set in a 9 o'clock position based on the reveiews in youtube.
Yes. Very much so. The noise reduction should be the very last pedal, of course. Try to even plug your chain in a different outlet than the one your amp (or if recording to a computer, different than the computer outlet). If you have a particularly loud distortion, have it be the last one before the noise reduction pedal.
Jul 09, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
BOSS AUDIO SYSTEMS Boss Ns2 Noise Suppressor Pedal Logo
516 people viewed this question
Top BOSS AUDIO SYSTEMS Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a BOSS AUDIO SYSTEMS Music Expert? Answer questions, earn points and help others
