Question about Sennheiser BW900 Bluetooth Headset
Problem pairing bw900 hs to blackberry bold 9000
When I pair the bw900 hs I receive the message connection to bw900 hs has succeeded. However, 30 seconds later the pairing is terminated.
  • 13,433 Answers
Follow these instructions
Some Bluetooth® enabled devices have a passkey that you must type before you can pair with them.
  1. In the Bluetooth setup application, click Search or Listen.
  2. If necessary, click a Bluetooth enabled device.
  3. If necessary, type the passkey for the Bluetooth enabled device on your BlackBerry® device.
  4. If necessary, type the passkey for the Bluetooth enabled device on the Bluetooth enabled device.
now connect
Connect to a paired Bluetooth enabled device To perform this task, you must turn on Bluetooth® technology.
  1. On the Home screen, click the Options icon.
  2. Click Bluetooth.
  3. Highlight a Bluetooth enabled device.
  4. Press the Menu key.
  5. Click Connect.
To disconnect from a paired Bluetooth enabled device, highlight the device. Press the Menu key. Click Disconnect.
Switch to a paired Bluetooth enabled device during a call To perform this task, you must turn on Bluetooth® technology.
  1. During a call, press the Menu key.
  2. Click Activate <Bluetooth device>.
Should work after being connected.
Posted on Sep 12, 2009
ATT BB Bold 9000 pairs with plantronics bluetooth headset fine but always drops connection when call is made
Make sure there are no other bluetooth devices interfering with the connectivity between headset and phone. Remove the Plantronics headset from the phone menu, if it's showing up. If possible, remove and re-attach the battery of the phone. Power off the headset. Pair the headset to the phone again and you should be okay.
Good luck from Headsets Direct!
Aug 11, 2011 | RIM BlackBerry Bold 9000 Smartphone
I am having problems getting pictures send to my Blackberry 9000 via Bluetooth from Nokia and other phone devices. Even though the device is paired with my Blackberry sending pictures fails (with error...
hey hi...may b i can solve ur problm...
1st open d media application,then lighlight the picture folder by putting the cursor on it.next click on the menu of the picture folder.....there u will find a option "receive through bluetooth".click on that.ucan receive ur files nw.
(Note:-u mst 1st swith on ur bluetooth and must have paired wid the device 4rm which u wish to receive data)
only after clicking on the "receive through bluetooth" the data must b send 2 the blackberry.....
hope u got it....
u can contect me at zeebonbarua@gmail.com 4 quarries..
gud luck
Aug 03, 2010 | RIM BlackBerry Bold 9000 Smartphone
Bluetooth will not activate on my Blackberry Bold 9000
Follow the below instruction:
Screen menu > Manage your connection > check mark in blue tooth place > search the blue tooth device and pair it
Mar 26, 2010 | RIM BlackBerry Bold 9000 Smartphone
Cannot pair vmx100 with blackberry bold 9000
In order to pair it with your phone, it must be in pairing mode first. If it has never been paired to another device before, just by opening the boom, the indicator light should flash alternately in red and blue, thus indicating it is in pairing mode. Otherwise, to force it to go into pairing mode, press and hold the volume (either + or -) whist opening the boom. It should flash alternately in red and blue. Only then, make the other device's b'luetooth application search for new devices. After a while, the VMX100 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful. Now, ot pair it with the other device (the VMX100 is able to pair to up to 4 different devices), make sure the previous device has its bluetooth radio turned off. Then, repeat the pairing process with the other device.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Mar 07, 2010 | RIM BlackBerry Bold 9000 Smartphone
Can't pair my blackberry bold to a parrot MKi9200
Hi
It is not possible
Reason being BlackBerry bluetooth is not highly advanced.
Oct 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Bluetooth headset pairing won't go away
you can disable blue tooth connections from the connections manager
Jul 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
How do I find the numirical passkey for my computer?
You can connect however type numerical key for pairing both the devices,for Eg:123 for your computer and 123 for your BB.
Jun 28, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry 8100 bluetooth pairing problem
after you have paired the two devices... the blackberry that is receiving the file has to be in receiving mode.
Go to MEDIA or music icon on your handheld where all of your tones are, hit the menu key and choose "receive using bluetooth" then hit send on the other handheld.
and there ya go !!!
its just another added security feature by RIM to avoid unwanted stuff being transferred .
Nov 18, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
Sennheiser BW900 Bluetooth Headset Logo
150 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
