Question about Brother MFC-5460CN InkJet Printer
Black ink will not print!
Black ink will not print, all others will. I just bought another black cartridge thinking it was bad...but no...it's the machine!
How can this be resolved? This machine is brand new!
Frustrated...
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Can print in color but not black changed cartridge still no black.
I've had this problem. Once it was because the ink I purchased at the local office supply was out of date. Check the side of the box. I bought a new cartridge and it worked just fine.
The other problem could be bad heads or dried up jets.
Apr 23, 2009 | HP DeskJet F380 All-In-One Printer
Printer won't print black color
Really silly I suppose, but...did you remove the protective tape from the cartridge?
Feb 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Ink cartridge replacement
I had the same problem, and after scouring around online for a few days, I learned that this is one of the biggest gripes about this printer. Basically, you're out of luck unless you replace EVERYTHING, even though you only want to print black (nuts, isn't it?). So I went out and bought all new color cartridges, and it STILL won't print. I think it's just a bad printer all around. :(
Sep 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Changed cartidges & now black and blue don't print on C88+
Try to remove and reinstall the blue and black cartridge and check if you punctured the plastic cap underneath the cartridge itself. then reinstall it and make sure you hear a click or it snaps in. try head cleaning cycle from the utility and print a nozzle check pattern. If same output maybe carts are bad. If that is a genuine epson ink cartridge, call epson and have the ink cartridges replace since they are new ones and for sure epson will send inks since you just bought it. make sure you have date of purchase handy.
pls dont 4get to rate solution if it helps... thanks!!
Apr 16, 2008 | Epson Stylus C88 InkJet Photo Printer
Won't print black
MY DELL 725 PRINT WILL NOT PRINT IN BLACK INK. I HAVE A NEW PRINTER. I EVEN BOUGHT A NEW INK CARTRIDGE AND IT STILL PRINTS IN GREEN ONLY. WHAT CAN I DO TO HAVE MY DOCUMENT PRINT IN BLACK?
Jan 01, 2008 | Dell 725 InkJet Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Brother MFC-5460CN InkJet Printer Logo
108 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
