Question about HP LaserJet 3015 All-In-One Printer
Fax error report,no fax detected
Dear sir
I have installed this machine but i am not getting fax.as it is complain from fax sender that they are not receiving fax tone after dialling
my fax no is 07239232058
Regards
arvind
Comm.error(0001)
just press red button few times. That means that there is some kind of interferences in tel line, yours or senders.
Apr 22, 2010 | Canon FAX L-120 Plain Paper Laser
Need to know what bod rate is on my fax
older fax machines used a 9600bps baud rate, meaning a transfer rate of 9600 bits per second. a Bit being an 7th/8th of a byte. The newer machines can transfer at 14400bps, which older machines can not read, as its too fast. thats why they asking the BAUD rate.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Retrieval of fax from memory
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
May 14, 2009 | Office Equipment & Supplies
Copy report after sending fax
it will be under reports, you can set all faxes to do a report after a fax has been sent, ill keep the terminology easy as
Brother, canon, konica blah blah all uses different terminology for it, but there is a setting in reports for user that they can turn on, it like error reporting if a fax deosnt go it will print out a error report so same thing to do with copy report.
regards
Fax Tech
Apr 01, 2009 | Office Equipment & Supplies
How can i get a fax from memory.
Solution: Printing reports and lists MX310
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Can't send a fax with Brother MFC-240C
Do you have DSL or any other kind of Digital Phone Line?
Oct 03, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Need fax out of memory
There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Aug 04, 2008 | Lexmark X5470 All-In-One InkJet Printer
Sender Id
Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif This is a descriptive title that identifies the sender -- usually the location of your fax machine or the name of your company or office. It is printed at the top of every fax you send. You can enter up to 32 characters. The first 16 characters will also be used as your Personal ID, which may appear on the displays or reports of other fax machines you are communicating with
Setting the TSI/CSI and Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif1 Press Menu/Exit to enter the menu.
2 Input speed access number 02. 3 Input up to 20 numbers and characters (0-9/Hyphen/ Space/+), press Enter. 4 Press Menu/Exit.
Sep 27, 2006 | OKIFAX 5950 Plain Paper LED Fax
HP LaserJet 3015 All-In-One Printer Logo
239 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
