Question about Acer Computers & Internet
The xp was reinstalled on my Emachine and the cpu program problem was solved,but the cd rom name was DISK(E)AND NOW IT'S DISK(7),HOW CAN I CHANGE THE CD ROM BACK TO DISK(E)?
  • Acer Master
  • 13,433 Answers
You just want to change the drive letter from something to E:?
Right click on my computer or computer which you will find from either your desktop or from start menu, select manage, on the manage windown, on the left side click on disk management.
find the CD ROM drive, right click, change path.
Select the Letter from the list, then click on change.
now from the list you can assing a new drive letter, the E: if you wish and if it is available, if something else is using E: then that something else will need to be moved from e: to something else first.
Posted on Sep 12, 2009
Cd rom on windows XP wont work?
how old is the computer cd rom might be time for new one
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 12, 2012 | Computers & Internet
Tip
How to Recover eMachines Notebook Windows Password
eMachines, as a brand-name laptop, is attractive to many netbooks users. We also call it as Acer eMachines for its developing history. We often receive letters from eMachine notebooks users on Acer eMachines password reset for forgotten eMachine administrator password. How to remove eMachines password or change eMachine password if I forgot Windows 7, XP, Vista password? Now, begin discuss the ways to unlock eMachine password.
1. Reset eMachines administrator password with other admin account
This means that we still can login our computer by accounts with administrative rights or privileges. Please never forget the default administrator, it may help much!
eMachines XP password reset from Safe Mode
A. Switch on eMachine Windows XP laptop and keep pressing F8.
B. Opt for "Safe Mode" and press "Enter" key at the Advanced Boot Option windows.
C. At login screen, choose the Administrator account and keep "Password" column blank (or input the changed password if the default Administrator account password has been changed before).
D. Start - Control Panel - User Accounts - select the account needed to change password - Change the password.
E. Input a new password, confirm the password again and then complete
Acer eMachine password removal on XP.
eMachines password recovery on Windows 7
We can recover forgotten password with built-in admin account:
A. Power on Acer eMachine computer and press the key: F8.
B. At the Windows - Advanced Boot Options, select "Safe Mode with Command Prompt" and press Enter to confirm. Then PC starts Windows.
C. Choose the Administrator account shown on the account screen, and then login windows - Administrator: cmd.exe. Input command: net user Lily abcd and Enter to confirm (Lily is the account needed to break password; abcd is the new password for the account).
D. After command finished, we can restart eMachine Win 7 laptop and login with account - Lily, password - abcd.
2. Break eMachines password with only guest account
We know that the guest account can not do more operations on a security PC. So, we have to refer to other way to retrieve the admin account for further operations.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
on Jul 08, 2011 | E-Machines eMachines Desktop PC
Tip
Recover / Restore forgotten password without reinstalling Windows
1. Download and burn Ophcrack (freeware).
2. Burn ISO file to a disk.
3. Attach an external CD ROM if your computer does not have one
4. Load the disk with the ISO file in the external CD ROM
5. Turn the computer on and tap F12 a few times on the Lenovo Screen. NOTE: Boot Manager options may change depending the on the model and brand of your computer.
6. Select Boot using CD/DVD ROM
7. Wait for the program to completely load until it shows you a picture with your password on it.
on Jun 02, 2010 | Computers & Internet
Cant get emachine to go past recovery management
LOL, Vista or Windows 7??
Check Disk UtilityTo run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If check disk does not solve the problem you might have to reinstall your operating system.
Apr 09, 2012 | Computers & Internet
Acer emachine e732z xp disply driver problem
make sure that the dvd burner is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 02, 2011 | E-Machines emachines (emachinees) CD-ROM...
I need help please!!! i've just installed dance ejay 7 on my netbook, i have an eMachines model eM250 from ACER with all drivers installed and up to date including direct x 9.0c installed and when i try to...
Dance ejay 7, System Requirements:
Pentium® 3, 800 MHz or higher. Windows® 98, ME, 2000, XP,Vista
512mb RAM.
1.4 GB free hard disk space.
4 x CD-ROM.
CD-Writer (for Audio CD Burning feature).
32 MB DirectX® 9.0 compatible Graphics Card (16bit colour, 1024 x 768, 32 MB).
DirectX® 9.0c (included on CD)
compatible sound card (16 bit).
Web browser.
Change your screen resolution to 1024x768 and try to run the the program.
Oct 23, 2010 | Digital Leisure DANCE EJAY for PC
Hello My Hp pavilion dv2000 is ready for vista but nowadays i install windows 7 home edition and after install my cd/dvd rom icon don't show in my computer. i try to solve this by removing disk drive...
Go to Control Panel-->Administrative Tools-->Computer Management
Your CD/DVD rom would be listed there... Just right click on the DVD rom and select"Change drive letter and path". Then select "Add" and change the drive letter..
Oct 06, 2010 | Computers & Internet
Needed to reinstall xp home-sp2 with my recovery cd-rom
Try changing the CD, if that dosn't solve the problem :
1. Format the whole hard disk using the default partition manager.
2. Install XP freshly.
Mar 13, 2009 | Microsoft Windows XP Home Edition
Missing wininet.dll no disk
probably u are trying to reinstall the same windows program that is damaged and is still in the cpu. find another windows disk and dowload this from "bios" (select the option "download from cd-rom") this will totally reset yr hard disk and all yr data and settings will be lost
Jan 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
Problem with computer
Hi. I'm Azrul from Malaysia. Your windows installation might be corrupted and the system files might have been modified by a virus. Here is a possible solution for you:
Insert your Windows XP Setup disk in the CD rom drive. Set your boot priority to the cd rom. Wait for the option to repair your Windows XP installation. Do not format or reinstall. Just repair.
Dec 21, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
