Question about Refrigerators
Our Kenmore EVL165NXRQ03 fridge/freezer (single unit with either freezer or fridge) never gets below 54 degrees and hasn't since installed gotten below 50 degrees. Could it be in demo mode ande if so how do I get it operating? We had one power interruption for 3 days coupla years ago and I don't know whether that affected it or not. Lights work and sometimes hear compressor motor come on but never really cold.
    Sergeant:
  • 222 Answers
How old is your refrigerator? Old enough for lint and dust to have accumulated around the bottom fan and coils?
Dirty coils can cause a multitude of problems and even give the appearance of a failing unit. Try cleaning the coils with a brush and vacuum as thoroughly as you can and be sure the bottom fan is running to pull air over them. It's a 'free' fix and you'd be surprised at how often such a simple 'repair' is all there was wrong with a refrigerant unit.
Good luck. Hope this helps.
Posted on Sep 12, 2009
Kenmore freezer running but not fridge
is it a fairly new fridge with dual compressors, if it a single unit, you may have blocked the door that lets the cold air into the fridge side with food, or the door could be stuck shut.the door is located in the upper corner next to the freezer side of the fridge.
Aug 31, 2014 | Kenmore Refrigerators
Recommended temp settings for freezer and fridge
The ideal freezer temperature is 0 to 5 degrees and the fridge section from 36 to 40 degrees. However, you will get more accurate responses if you leave the model number of your exact unit.
Jul 15, 2013 | Computers & Internet
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Model#25360722000 is this a freezer or fridge? kenmore
What is it? A single door or a double door unit. If a single door, what temperature does it go down to? lower than 0 deg. c or +/- 3 to 5 deg. c In other words, lower than o it is a freezer. Above 1, it is a fridge..
Jun 03, 2010 | Kenmore Freezers
Freezer gets 10 below 0 and fridge is 60 degrees
Check and clean the condensor coils. Make sure the air ducts are free f frost and not blocked by anything. Make sure the light is turning off when the door is closed.
Eric
Sep 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
