Question about Garden
Chainsaw shut off as soon as i let go of throttle.changed sparkpug and got new fuel/mixture.still wont try to start
    President:
  • 583 Answers
Hi try this ,with a small screwdriver screw the H and L screws in until they stop, not hard , then back the h screw out 1 1/4 turnsnext back the l screw out 1 turn tyhen screw the idle screw in acouple of turns Now this is easier if you can put the chainbar in a viceso the chain can run freely, you dont have to ,but it helps.Start her up run it up to full throttle and screw the H screwin and outuntill it runs the sweetest then back off 1/8 th of a turn,next let it idle if it will, if it wont ,screw the idle screw in a bit till it stays running. THEN screw L in and out also adjusting the idle speed until you get it running not too slow but not fast enough to make th e chain run constantly-=--- try that and see how you go also make sure the air filter is CLEAN, good luck ----"youdoit"
Posted on Sep 12, 2009
My chainsaw will run only full throttle and when you let of of the trigger it wont idle it will die
Hey on the carburetor there is 2 mixture screws 1 is for idle up to 1/4 throttle the other is for 1/4 to full throttle the one for idle is closest to the engine. screw it all the way in then unwind it 1 turn. The screw the furthest from the engine screw it all the way in then unscrew it 1 1/4 turns Try to start the saw with just a little throttle. this setting is pretty standard. When you get it to idle then rev the saw and it cuts out as it returns to idle it's running to rich. Just adjust the screw in a little say 1/8 at a time. When it's to lean as soon as you throttle on it will stall. If you have no luck with this...you have a air leak from the carby gasket or the bolts are loose or a blocked exhaust
Oct 14, 2013 | Earthquake Gas Chainsaw, 14 inch CS3814...
Esco chainsaw model 162
The adjuster screws on a chainsaw carb are fuel screws,not air screws, so by unscrewing them anti clockwise will richen the mixture, there are normally three screws, an engine idle screw, this will operate against the throttle spindle, a screw marked L, this will adjust the fuel mixture from idle to half throttle including acceleration, and a screw marked H, this will ajust the fuel mixture from half throttle to full revs, as this will increase the maximum revs it is very importent not to exceed the manufacturers no load speeds, so a engine tacometer should be used to check this, over speeding can seriously damage the engine.
May 06, 2013 | Garden
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
MS 310 chainsaw wont keep running
If you have a spark and compression it only leaves fueling/air problem.
to reset carb to standard settings screw both H and L screws right in. then unscrew the anticlockwise (L) 1 full turn. (H) 3/4of a turn, that should set it back to standard settings.
Oct 09, 2012 | Stihl Garden
Stihl ts410 wont take high revs
after some use the screen inside the muffler gets plugged with carbon and blocks the exhaust flow try and run it with out the muffler they are made to open to clean the screen off
Aug 02, 2012 | Garden
What do theT H L adjustment screws mean
These are the fuel adjustment screws, the L screw will adjust the fuel mixture from idle to half throttle, the H screw will adjust the fuel mixture from half throttle to maximum throttle, this will also control the maximum revs, the T screw is the tick over or idle adjust screw
Oct 12, 2011 | Poulan 18" Wild Thing Chainsaw
Starts with starting fluid runs for a few seconds then shuts down
Good test. Do not keep doing that.
Make a new and accurate gas/oil mixture. Empty and refill. Secure cap. Be sure to flood system during start attempt. Can you smell gas? Oops, too much, better wait 30 seconds for full evaporation.
Two little screws near carb. Both are actually needles and probably have a visible spring which keeps them from vibrating to a new position while in use. One fuel/air mixture at low idle (start). One fuel/air mixture at high RPM.
Try 1 1/2 full turns open from fully closed. Once to get it to idle roughly, adjust to a smooth idle. Do the same at full throttle. You will notice that the more you shut the full throttle down, the higher the RPM will go (assuming that it is near correct). Do not run it to lean. The mechanics of the motor needs the oil from the gas.
Smile always.
Jun 03, 2011 | Garden
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Sep 05, 2009 | Garden
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
