Question about Whirlpool SF368WWH Gas Kitchen Range
Oven doesn't stay on
My oven preheats and works for about 45 minutes. I hear the gas shut off and come back on in intervals, but then it just stops the control panel still has the degree of the oven display but the oven will cool completely.
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 409 Answers
SOURCE: whirlpool gs475lems range oven problems
it means bake range over temperature.
have a technician check out the oven temp sensor. you may have a short in wiring or it may need to be replaced.
if problem still persists, replace the clock.
Posted on Sep 13, 2008
  • 70 Answers
SOURCE: Whirlpool GW395LEPQ console is completely black and E2 and F3 err
If digits on control board does not shows up after resetting power you need a new control board(part# 9760013 $174.20).
sensor for this model(part# 4455636 $89.78)
Posted on Dec 02, 2008
  • 31 Answers
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Posted on Feb 08, 2009
  • 135 Answers
SOURCE: my oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Posted on Sep 02, 2009
  • 262 Answers
SOURCE: I need to know how much it would cost to purchase
Most controlboards can't handel a power surge more than 125V and is a reasonable expanation.
Your model number is missing a number at the end and if your model # is GS563LXSS0 or GS563LXSS1 then the Main Control part # is a W10116542
Posted on Jan 09, 2010
Testimonial: "The Model# did have the 0 on the end. What is the average purchase price for this part, can you help me w that one and where I might start locating "
0 characters
1 Points
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Fan stays on long after oven is shut off in brand new viking daul fuel range. It's been on now for 45 minutes. All controls are on OFF.
loads of ovens do this. It's a pain, especially if you eat in the kitchen. If you switch the appliance off and on at the wall it usually stops it. Why the fan stays on, god knows. pointless.
Jan 12, 2011 | Viking VDSC365-6B Dual Fuel (Electric and...
Maytag Prec touch 750 lower oven takes too long to preheat
This is a common problem that happens when the oven gas control valve is sticking. This can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 23, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
I turn on oven and can smell gas for a minute,then hear it ignite
I tapped on the valve a couple of times and it seems to work fine now.
Dec 09, 2009 | Kitchen Ranges
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Sep 30, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My Delonghi gas oven takes nearly 45 minutes to preheat!
I would be suspicious of the thermostat. It or the sensing element may have failed.
Jan 28, 2009 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Takes to long to Preheat
the burner element iside the oven(the rod that glow,s orange) is burned out,even though it glows and the oven is warm,the element is worn out and has to be replaced,unplug the oven,shutt off gas supply to oven,pull off back cover youll see the rod coming thru each end of the rod will have 1 wire unplug the wire off the clip,go back to the inside the oven follow the rod to the back youll see 2 screws holding the rod unscrew and pull rod thru,easy job and elements arent exspensive,but make sure to unplug oven,and shut off gas
Jul 09, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Whirlpool gs475lems range oven problems
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Dec 02, 2007 | Whirlpool GS475LEKS Gas Kitchen Range
Maytag Gemini electric oven
Well my friend these type ovens have eyes and sensers. It could be that you left something on the sensor when you were cleaning it. That is if it is not self cleaning. Self cleaning gets real hot and could affect your appliance in some way. It shouldn't but it might.
Aug 06, 2007 | Maytag MER6772 Gemini Electric Kitchen...
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool SF368WWH Gas Kitchen Range Logo
52 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
