What is power supplier, ie: smps
Dell 2350 win xp wont boot, do get bios and shows hard drive then dies
no boot device found
  • 21 Answers
If you see the BIOS and Drive in the Bios then Windows does not have the proper driver...you need to re-install using the F6 selection during installation...the first 30 seconds or so of the install CD booting up watch for this at the bottom of the screen and use the specific Dell Drivers disks when prompted.
You should be able to then select Enter on the first screen and then Windows will find the old OS and provide you the ability to do a Repair Install so you won't loose any applications or other devices.
Posted on Sep 12, 2009
Dell Dimension not used for about a month. Has win XP telling me BOOT DEVICE MISSING PRESS F1 OR INSERT SYSTEM DISK.
Boot the pc and press F2 to enter the bios, check under drives to see if it is listed, if not showing here then the drive is dead and needs replacing.
Sep 25, 2014 | Dell Dimension 2350 PC Desktop
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
When turn on computer NO WINDOWS XP .On the screen was PXE-E53 : No boot file name received PXE-MOF: Existing Broadcom PXE ROM Operating System not found
That means your computer trying to boot from LAN port. Go bios and change the settings of PXE boot to disable and make Hard disk as first boot device. Save the settings and restart your pc. It will work
Mar 31, 2011 | Acer TravelMate 4101WLMi Notebook
I have the same problem
check ur all connections on motherboard..also try to change power supplier i.e. SMPS
Jul 31, 2009 | Dell Dimension 2350 PC Desktop
Hard drive died & replaced with a new hd
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
May 29, 2009 | Dell Latitude D505 Notebook
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
