Question about SanDisk Sansa e260 MP3 Player
Sansa e260 I cant switch to recovery mode is there anotherway to do so?
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
Sansa e260 says cannpt load image switch to recovery mode
download the update software and install then.. lock your sansa, hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer... Download the sansa update software
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe).
You may need to make sure you are connected to a 2.0 USB port if your computer is not IDing it, try a friends computer or a labtop... USB modes msc...
Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate...
Jun 06, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e260 dosent read in the computer
well if you are trying to use itunes, then it won't show up. Only ipods or iphones do.
Nov 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Download the Sansa Recovery Tool from sandisk's website
Jul 06, 2008 | SanDisk Sansa e260 MP3 Player
Problems with Sansa e250 + Rockbox
Go to Sandisk's website and download the Sansa Recovery Tool
Jul 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Donwload the Sansa Recovery Tool form Sandisk's website
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
1)Shut down the player.
2) Make sure the hold switch is engaged.
3) Hold down Reset and Menu buttons until system starts up in recovery mode.
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Please refer to: http://www.fixya.com/support/t114495-format
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
SanDisk Sansa e260 MP3 Player Logo
27 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
