Question about Kenmore Washing Machines
Front loading washer won't spin
My front loading washer (kenmore super capacity 3.5) won't spin or drain. The control panel lights up but it won't spin or drain. It filled with water for the last load of wash but then stopped. I emptied it, thinking the clothes (jeans) were too heavy but it still won't do anything. The machine is only 3 years old. Help!!
  • koezuna Sep 12, 2009
    this doesn't begin to solve the problem!
My amana washer wont spin and does not drain
Posted on Sep 12, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My washer won't spin out at the end of the load
you should check the brushes on the motor they wear down which stops the motor spinning.you can ring a washing machine repair shop give them yr modal number and they can alder some new ones,this is what i did and my machine worked fine after that.
Mar 24, 2013 | Kenmore Washing Machines
Ge washer won't let water spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
Won't spin
heatman101
Jul 17, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My model 20632 990 Kenmore Super Capacity clotheswasher wont spin or drain
heatman101
Oct 12, 2010 | Kenmore Washing Machines
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore front load won't drain spins then blinks no spin
Yes this is the place, but you have to mop up the water or it would flood the place; clean out the muck from the filter and refit carefully. You have to clean your filter according to usage, the filter does not self clean, no way.
Feb 25, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Super Capacity front loading washer that has stopped.
Hello SMCCRAVE,
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Stator/rotor
Drive motor
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore 46462 Front Load Washer
Washing Machines Logo
665 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
