Question about Frigidaire 24 in. FDBB945DC Stainless Steel Built-in Dishwasher
Dishwasher fills, but wont move to the next cycle
Frigidaire FDB949GFS2. I checked the the door lock, tried setting it for different washes. I'm not sure where to look now?
Thanks,
Scott
  • 33 Answers
In the bottum of the inside of the Dishwasher neer the front is a flote its round. pull it up and down you should hear a clicking from the rellay. the flote sometimes gets stuck this will let it know to start the sikell.
Posted on Sep 12, 2009
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
Won't Fill and will attempt to run wash cycle when turned off and door is closed
Hello ddux97 - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink).
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Check inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• If this is a new install, then make sure the unit is not pressed up against the cabinet and the fill tube is not squeezed closed.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Make sure the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some models of Frigidaire dishwashers use a water pressure switch that will shut off the water valve if the tub over fills. These models do not have floats.
I hope these troubleshooting tips help you in some small way.
Jun 20, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
Dishwasher is locked. How do I unlock it to set the next wash cycle?
I am not sure if this dishwasher does have a lock mode. See this manual.
It is possible to use the Cancel button to get it out of the unknown state.
Alternatively turn the power off and on and see if there is any difference
Feb 13, 2011 | Frigidaire Dishwashers
After it fills and starts to wash my dishwasher
Reseat the little rubber gasket along the door. Pull it out a little bit
Aug 16, 2009 | Whirlpool DU930PWS Built-in Dishwasher
FRIGIDAIRE DISHWASHER CLEAN LIGHT FLASHING WILL NOT WASH OR DO ANYTHING
Do what 'mrrevo'l says to reset the dishwasher, and next time, try not to open the door during the wash cycle. Make sure that all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Jul 15, 2009 | Dishwashers
Replacing detergent dispenser
take the door apart, the dispenser will pop out and you can rehok the new. make sure the seal is good
Feb 17, 2009 | Frigidaire FDB949GF Dishwasher
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire 24 in. FDBB945DC Stainless Steel Built-in Dishwasher Logo
194 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
