Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Need to forward two UDP ports
Hi, I need to forward two UDP ports. Do I need to know anything about the router? It's across the hall.
I tried to find info on the router by typing the default gateway into the browser, but it couldn't connect. Otherwise, I have good connection for surfing.
If I don't need to know about the router, then how do I forward (I cannot find the "forward UDP button", ha!)
Running XP sp2, home edition
nanoman
  • drphyto Sep 12, 2009
    Hi 2Gigs;
    I guess I do need to connect to the router then. The default gateway is 10.0.1.1
    But it won't connect when I type it into the browser. (by the way, the browser sticks an http:// onto it.)
    The router is hooked to the Comcast cable. Do you have any idea why it wouldn't connect? If it did, I would still need the username and password wouldn't I. I was going to try admin and blank, etc. He gave me the psk so I can surf, but I'd rather not worry him with me poking around in his router with port forwarding. I don't know him, he's just my neighbor.
  • Raymond Roque
    Raymond Roque May 11, 2010
    You need to access the configuration page of the router. What is your default gateway? Do you have DSL or Cable connection?
  • 21 Answers
Your going to have to get in to the administration portion of the router to setup port forwarding.....without this access you can't do anything to forward the ports....
There should be someone who has this access as it sounds like your in a dorm/apartment environment....
Posted on Sep 12, 2009
Testimonial: "Good help. Most appreciated. "
  • KevinEBrown Sep 12, 2009
    Well if it is connected to the Comcast Modem it is still your gateway and Comcast is internally seen as the WAN on the Router. So it is correct that the HTTP is added and your browser should be going to the router/Gateway.
    Are you getting a Login Prompt? With the right setup you can actually block access to the Router and or limit access to the Router Login area which may be the case.
    I have my router setup to only allow 192.168.2.100 to login...everyone else is blocked from access to port 80 on 192.168.2.254...keeps the kids out of it and more secure...IMO
  • 281 Answers
You need to plug you computer with a cat-5 [internet] cable then type in the default gateway,, and login
Default user name = admin
default pass = admin or password or keep it blank
if you get in look for port forwarding,
if you cant login.. then the username/password was set from default,
you can set it back to default setting, by restarting the router, to do that look for a small hole in the back it should say reset, push and hold this to reset
  • Matthew Albert
    Matthew Albert Sep 12, 2009
    sorry let me reword that first part..
    You need to plug your computer into the router using a cat 5[internet] cable to log into your routor,
    Most router come setup to not alow access to router admin via wireless
  • 13,433 Answers
Try http://portforward.com/ and let me know if you need more help after going over that.
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
My Router doesn't allow me to open up my ports for my Xbox. My NAT type is Strict and it doesn't allow me to communicate with other people or even get a good connection. I would like some...
If you know how to set the port forwarding on your router/modem then you need to set the following ports up to forward to your Xbox's IP address:
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You can read the whole web page by clicking here:
If you can't click the link above you can copy and paste the following into the address line of your web browser:
http://support.microsoft.com/kb/908874
Hope that helps.
May 19, 2011 | Computers & Internet
I cannot get my ps3 game to work. it says to consult my routers user manual to enable the setting in the games booklet. i cant because the manual has been lost. it requires a UDP port 9301. and i need to...
You'll need to setup port forwarding on your router.
From a computer use an internet browser such as Internet Explorer.
Assuming the router is using default settings.
1) In the address bar type in 192.168.1.1
2) You'll be asked for a username and password. Username is 'admin' and the password is 'password', no quotations.
3) Click on 'Port Forwarding / Port Triggering' on the left side bar.
4) Click on the Port Forwarding radio button.
5) Click the 'Add Custom Service' button.
6) For Service Name call it something meaningful, such as 'PS3.
7) For Service Type choose 'TCP/UDP'.
8) For starting port and ending port use '9301'.
9) For server IP use the IP address of the PS3, you can get this in the PS3 menu under Network Settings.
10) Click Apply
UPnP is supported by your router. On the left side bar, click 'UPnP'.
Feb 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
How do I switch the NAT type from Moderate to Open? I need to forward the UDP and TCP ports? How do I do that? I'm trying to do that so I can switch my NAT type for Xbox live
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Jan 11, 2011 | Computers & Internet
Need 2 open NAT
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called "opening ports" or "port forwarding."
  • Port 88 (UDP)
  • Port 80 (TCP)
For Belkin router follow this steps
Configuring port forwarding
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in http://192.168.2.1
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Disable Firwall
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 10, 2011 | Belkin (F5D8231-4) Wireless Router...
PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
Can not get my xbox to connect to my netgear 614v7 router am using a lan connection but it cant get a IP address from the router any ideas ??
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address 192.168.1.50.
Click On 'Apply'.
10. Log Out of the Router Page.
Please repeat Steps 3 – 7 to configure the ports “UDP/TCP 3074”.
Jan 03, 2010 | NetGear WGR614 Wireless Router
On my echolink progtam it says to use port 5198 or 5199, how do I do it?
access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
For belkin router http://192.168.15.1
type user nams as "admin" and password as "admin" or blank or "password"
Then go to NAT and prot forwarding .
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
then go to NAT
Aug 31, 2009 | Computers & Internet
What is portforwarding
You need to login to your router and go to firewall or virtual servers.  In there you can setup port forwarding.  The goal is to forward external (internet) traffic to a specific internal machine (your PS3).  You do this on a per TCP/UDP port basis and must specify the appropriate external TCP and/or UDP port and internal TCP and/or UDP port.  Sounds harder than it is.
Or you can setup your PS3 in your router's DMZ (Demiliterized Zone).  This sets up the router to forward ALL internet sourced traffic to a specific machine (your PS3).  This is the easier way to do it so you don't have to worry about specific TCP/UDP port numbers.
Jan 24, 2009 | Linksys Wireless-G WRT54GX Router...
I have netgear wirless router but i hardline ps3 but i keep getting nat type 3 i need to know what ports to open on modem to get to nat type 2 can you help
the Router.
Port numbers:TCP: 80, 443, 5223 and UDP: 3478, 3479.It is in this context, I would suggest you to please try with the
Address as: 4.2.2.2
4. Give a name to the service (for example, PS1).
port as 88.
7. Hit ‘Apply’.
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
177 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
