Question about Kenmore Oasis HE 27082 Top Load Washer
I keep getting a code F1 on my OasisHE. It only
I keep getting a code F1 on my OasisHE. It only happens when washer is filling with water
  • Anonymous Mar 25, 2014
    How do you wash a sleeping pillow in the OASIS HE washer
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an error code F1. There is NO explanation in the manual just call a technician....what can i do to check things out? the wassher begins to fill up with water then stops abruptly flashing...
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%#
Aug 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a kenmore elite oasishe washer and it keeps setting off messages that I am not sure the meaning of. It finished washing the other day and it had hc on the machine what does this mean?
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min.
Restore power to the washer and try running a short cycle.
This will help clear any irregularities that the control board may have encountered.
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
F1 error code
This was copied from a website called WORLD OF WASHERS....I just copied the whole paragraph......sounds like some $$$
Let me know if this helps.......mtg
I am new to this online blog stuff, so I figured an email would be best. I own a Kenmore Elite Oasis washer Model #110.27042602. Everytime we try to use the washer we get error code F1 flashing. This happens withins seconds of the machine first starting to fill and about ten times thereafter until enough water gets into the tub for balance, I assume. We have started pouring about 2 gallons of water onto the clothes in the tub by hand before starting the machine which usually works. About half the time the machine stops again between wash and rinse cycle as it starts to fill with water again.
In my online research, I guess its good we don't have error code F51, but this is a pain and 1 year warranty has passed. It appears I may need to get a new Machine Motor Control Assembly. Any thoughts????
Thank you,
Darrell S.
Darrell,
I'm probably not going to tell you anything you don't already know. You know you may have to replace the motor control assembly, so you have done your due diligence.
I found a thread related to your problem at the "Samurai Appliance Repair Forums" at ApplianceGuru.com. That link will take you to the discussion, in case you haven't already read it. The poster described a situation identical to yours, and I have also read of this problem at other sites on the web.
Contained within that thread is a link to a Service Matters (Whirlpool Corp.) tech sheet related to the F1 error code. This is the document any qualified servicer will refer to when addressing your problem. Here is a link to that sheet in case you want to have it on hand in the event of a service call.
The tech sheet calls to replace the control, but only after three other tests have been conducted. Everything I have read indicates the control will be replaced the vast majority of the time. I am not a technician, but I would say there really is no way around that.
Please keep in mind that this sheet applies to specific models and serial numbers within the Whirlpool line. There may be a separate sheet for your washer, but I imagine the end result is the same.
The million dollar question is how much will such a repair cost. I am seeing prices ranging from $150 to $200 just for the part. With labor, you will probably have at least $300 invested in this repair. I would encourage you to contact Whirlpool at 866-769-7260. I have read instances of other owners receiving satisfactory service in out-of-warranty situations via this number. Whirlpool knows these washers are ****, so they no doubt have a scripted procedure in place to deal with these situations. Be firm, but also be polite. Maybe drop the word "recall" and see what happens.
Apr 11, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio F1 code
have the same the washer show F1 I have to hit pause start 3 time befor it will wash severly people have the same proble with this whirlpool washer it is a tiner proble i hve been tool.
Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
KENMORE OASIS
I jhavent got to figure out what an F1 is. I suspect its a "Fill" code 1?
Does it fill with water okay? If it dosnt fill within a cretian time I bet the computer see this and causes a F1? But Im guessing.
If it is this take your hoses off the washer not the faucet. put loose ends in the washer tub and hold em down while Turning on the water. Look for rust, sand or any thing that might be coming into the screens. If you have low water pressure this could be the cause also. But only remove the hose on the faucet end if you have low water pressure then look for the screens on the faucet end.
Also check the inlet of the washer at the water valve for mud, dirt or anything.
I need to know if this is what an F1 code is if you wouldn't mind posting back and if this helps you please rate me as high as you can. Thank you and good luck.
Oct 23, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
