Question about Canon imageRUNNER C6800 Copier
Canon ir6800c error E00000-0030
I have this error
E00000-0030
what is this error ??
How can i solveit ??
waiting your help
  • Sergey Artuganov
    Sergey Artuganov May 11, 2010
    This problem take a part? then the fusers lamp is wrong or disconnect.
    Please, be shore, that the connections of fuser lamp, it's on fusers
    part of the copiers, is on work?, The second, tes please the thermistor
    section, if the thermistor dous notwork, the eror 000 will be the same.
    And then, u mast test the thermo fuze, this own, and all about I told u
    is situated in fusers part and remooved very easy. Weel, then u test
    will be finished your copier dous not started, u must push the buttom
    wich is on ander the back cover in to the right and down place near the
    controller of DC. Than u push it, u can starting the copier. My email
    goodgold@inbox.ru Good lark
  • 78 Answers
After power on temp does not reach 50 deg C within 420 sec check main thermistor thermal switch and heater then enter service mode *28* copier function clear err and then retstart copier
Posted on Sep 12, 2009
How do I fix error code E000001
According to some Canon forums, this may be caused by over-heating. Perhaps turning it off and waiting for about 1/2 hour will help. If that does not help, strongly recommend to call the canon tech support.
Apr 28, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Tip
Service mode entering
to enter the service mode for canon IR5800C & IR6800C type :
  1. *
  2. press at the same time from keypad these number 2 8
  3. *
on Oct 22, 2010 | Office Equipment & Supplies
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
What is responsible for system error e225
have listing of most common codes here:
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
system error e225 refer to bad connection or power failure to the scanner, sometime can be solved, please follow this procedure:
1. switch machine on and wait till fully initialize, while it is "alive" disconnect power cord
2. leave disconnected for 10min
3. if possible - connect to known working different power socket (directly to the wall socket! no extensions, no power boards!)
4. wait till fully initialized, check if error still display, if not - problem solved,
if still error is displayed, go to canon site (this is not us unit, select therefore your appropriate division, somewhere there find contact and ask them for firmware update:
canada:
http://www.canon.ca/inetCA/en/serviceDetail?m=load&id=5&sid=28&mid=0002200586&type=S
australia:
https://www.canon.com.au/about-canon/contact
europe:
http://www.canon-europe.com/For_Home/Product_Finder/Multifunctionals/Laser/i-SENSYS_MF4380DN/
hope this will help you find correct solution, do not forget to vote...
Jan 12, 2015 | Canon I-sensys MF4010 All-In-One Laser...
Please wait a moment error canon ir 400
hi. there is a problem with the hard drive unit and need to be replaced .
Oct 08, 2013 | Canon imageRUNNER 400S Copier
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
Di layar mesin canon iPF9000 keluar tulisan hardware error 03130031-2F17
not sure of solution but the error relates to a problem with the Platen fan, waiting to find a solution myelf hope this helps...
Oct 19, 2010 | Canon imagePROGRAF iPF9000 InkJet Printer
Error U163 appear how can i fix this printer problem on my canon mx328
When this error appear in the lcd control panel of your printer, do this.
1. Press and Hold the STOP/RESET button and wait until itself restart.
2. When the printer restarted release the STOP/RESET button and wait until it fully initialize.
then try printing again.
Please rate this answer. Thanks for using Fixya.
You can also view and rate my helpful tip for this kind of error in Canon Pixma MX328 all-in-one printer
Aug 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Apr 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Help
Here is a link to an original manual for sale. I am still researching a free manual or other instructions directly related to your question. I will post further as soon as it becomes available.
Jan 03, 2008 | Office Equipment & Supplies
Canon imageRUNNER C6800 Copier Logo
267 people viewed this question
old marine
old marine
