Question about HP LaserJet 3050 All-In-One Printer
Document feeder pulls in multiple pages
Doc feeder pulls in multiple pages on faxing / copying
It's the separation pad assembly... I just replaced it (part RM1-0890-000 or RM1-0891-000); works perfectly now. Look it up so you can see what it looks like...
Now take out that part and disassemble it. Flip the rubber pad ---- you'll need to poke a new hole -- reassemble and install.
Posted on Jun 24, 2010
    Novelist:
  • 85 Answers
Try FANNING the paper before loading into tray. The air in between each sheet should help.
You may find more help here...
HTML clipboard HTML clipboardHow to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Posted on Sep 12, 2009
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
Document feeder pulls multiple pages
Sir/Mam,
Mite want to have the rollers cleaned. use a damp rag and soap and water. The separation pad mite need replacement. that's the device below the paper.in the document feeder. where the paper goes in.
Feb 24, 2014 | Konica Minolta Bizhub C253 With Document...
Feeds document too far before it starts copying.
The doc feeder is a little finiky, try letting go of the doc as soon as the feeder detects a doc in place and not force it through the feed slot.
Jan 05, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Where is the document feeder cover?
The doc. feeder cover is at the very top of your machine, it covers the rollers that pull in a document when you are faxing or copying.
Aug 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP LaserJet 3050 All-In-One Printer Logo
356 people viewed this question
Seeker5211
Seeker5211
