I have a opticon h19a i pressed the power on button to turn it on as i do every morning. except yesterday morning it stayed on the start up screen with the make logo which happens when you turn it on at the start. what can i do to get it working, i try to reset it ,no go
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Display window stays on screen, buttons won't work
Sounds like one of the buttons on the monitor is stuck in. See if you can unstick them by pressing them infirmly, but not too hard, several times. Try each one in succession. Hope this helps!
Jan 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Won't power up
There are more people around having the same problem. The player doesn't work anymore after a few weeks or months.
Think the best you can do is use of your warranty...and try to get a new one.
Mar 25, 2008 | Audio Players & Recorders
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Open Questions:
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
