Question about Dishwashers
MR WILLIAMS ERROR CODE A13 ON AN INDESIT DISHWASHER
    Problem Solver:
  • 17 Answers
Hi error code A13 means the soap dispensor on the inside of your dishwaher door is shorting out and will need to be replaced.
This is a fairly quick job and is relativly cheap to do
Posted on Dec 11, 2007
Indesit dishwasher error codes
Temperature timeout - Maximum time to reach temperature elapsed.
Dado
Aug 20, 2014 | Indesit Dishwashers
Hello What does the error code A13 represent. The soap dispenser seems Ok. Could it be related to something else. The machine starts up Ok, but about 6 seconds into a cycle A13 flashes up and the...
As you correctly pointed out A13 error is linked to the failure of the detergent dispenser lid operation.
If the lid is not opening at the correct time in the wash cycle, then the detergent will not be getting dispensed.
Either the controller circuit that operates the lid is faulty or the lid solenoid is faulty.
You can check the parts at this site.
Mar 20, 2011 | Indesit 24 in. DE73 Evolution...
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDE 1005 error code
Replace the control board
May 22, 2008 | Dishwashers
Indesit D61 Error Code 2... what does it mean?
have no access to manual. but you could...
try to recycle the power. shut off breaker or unplug for a minute or two. then turn back on. it may reset.
good luck
mark
Dec 27, 2007 | Indesit 24 in. D61 Free-standing...
Indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
May 06, 2007 | Indesit 24 in. DE73 Evolution...
A13 error code
It seems to me that there isn't any problem with the normal washing cycle. The problem you have could be related to your dishwasher's detergant dispenser lid. I reckon that the relevant part isn't functioning normally. You can simply check out the claws placed on the detergant lid. If there is a spring inside, it might be damaged.
Apr 16, 2007 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
320 people viewed this question
Top Dishwashers Experts
