Question about Refrigerators
PULLED FRIDGE OUT, REMOVED BACK PANEL, EVAPORATOR
WHIRLPOOL ....PULLED FRIDGE OUT, REMOVED BACK PANEL, EVAPORATOR FAN WAS NOT SPINNIGN...SPUN IT BY HAND AND IT STARTED TO WORK AGAIN. IS IT A BAD FAN MOTOR?
  • Refrigerators Master
  • 1,606 Answers
Yes , motor is bad . May not start , next time cuts off . The fan in the back by the compressor , is called the condensor fan motor . I would suggest cleaning the coils in front at the bottom , of dust , lint , pet hair , etc , before replaceing the fan motor . Also , clean the fan blade before reinstalling the motor .
Posted on Sep 12, 2009
Kenmore Fridge 596.76509500
KentC, This was my post on a model like yours.  Read thru this and let me know what you find.   If the ice/frost buildup is fairly thick and only on the back freezer panel then you have a defrost problem. Most likely the defrost thermostat is bad. It would be hard to explain how to test this in writing but there is a tech sheet underneath the fridge behind the grill on the r/f. It is in plastic which is stuck to the fridge. This tech sheet will tell you how to put it into diagnostic mode. First take the back panel of the freezer off (may need to get frost off first). Should be four 1/4" screws in each corner of the panel to remove. Will need to remove racks, door (should just lift off), and ice maker first. Remove vent in center of freezer panel by pushing up little tab in the center of the vent and using a screw driver to pop it loose on each side of the vent. Then remove thermistor cover on right hand side of panel. Remove (by pushing thru) ice maker plug. Once the panel is off put the fridge into defrost by the instructions on the tech sheet. If it goes into defrost (heater will get hot) then the main control board is bad. If not shut the doors to reset, defrost evaporator with a hair dryer and remove the defrost thermostat. It is a little metal round piece with two wires coming out of it and just clips onto the evaporator. Cut the two wires coming out of the thermostat, strip them back and splice them together. Now put it into defrost again. If the heater comes on then you know the thermostat is bad. Diagnostics mode can also test all functions i.e. condensor motor, compressor, evaporator fan, and thermistors. With all of that said, if it isn't a thick frost buildup the evaporator fan motor may be bad which is the most common repair on this model. It sits just behind the vent in the center of the freezer panel. Let me know what you find.
Oct 20, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works, warm air in fridge.
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool refrigerator is not cooliing refrigerator half not sure evaporator fan working model et1mhkxmb08
If the fan is working, then there is likely ice build-up in the vent between fridge and freezer. If you remove the farthest rear panel in the freezer and then pull the venting in the fridge and clean out all the ice, then the air can flow to the fridge again. It is also recommended to keep coils and compressor free of dust and make sure the drain hose is allowing water to drain into the drip tray in the back bottom of the unit.
Jul 11, 2010 | Whirlpool Refrigerators
Center support is hot
Pull the fridge out from the wall , and remove the rear panel . Check to see if the fan which cools the compressor is running . If not , it will have to be replaced . You may can get it started , by turning the blade by hand , but , it will still have to be replaced as it will stop again . If it is turning , your coils need to be cleaned of dust , lint , pet hair , etc . Also , the fridge has to have a back panel , so it will pull air over the coils and compressor , to keep them cool .
Aug 23, 2009 | Whirlpool Refrigerators
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Freezer on bottom works fine, fridge part dosnt
it sounds like the timer is going bad.... there is a timer that runs the fridge for 6 hrs. and defrosts for 20 mins. if the contacts are pitted ,it will run for shorted periods ..... this timer can be located anywhere from behind the unit where the compressor is to inside the regrigerator compartment ...
May 23, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge isn't cold
First thing I would check is the evaporator fan in the freezer to make sure its working. About the copper lines, one should be cold to the touch and the other should be hot. if both are cold your compressor may be locked up. Or if its a whirlpool build unit I would also check to make sure the relay on the ompressor is good.Pull it off the compressor and shake it. If you hear like a lot of little pebles shaking in it its bad and need replacement. that was a common problem with some whirlpool units. If that is good remove the back of the freezer and check the evaporator coils to see if there is a frost pattern on it. If not your compressor like I said may be bad or you have a refrigerant leak and there is no more gas in it. Good luck
Jul 19, 2007 | Kenmore 74522 Top Freezer Refrigerator
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
249 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
