Question about Compaq MV 500 Monitor
Fail controls image compress horizontaly and vertical is big
0 characters
1 Points
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply:
Jan 27, 2010 | ViewSonic VX2235WM Monitor
The display of my monitor is aligned horizontaly
replace the vertical IC (TDA9302h or STV9302a) or the capacitor near the vertical IC... the value is 16v/1000uf.....
Jun 06, 2009 | AOC 5 En 15" CRT Monitor
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Mar 17, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor displaying everything horizontally
Some monitors don't give orientation feedback to the video card to auto change the orientation when you move from a horizontal screen to vertical. what you need to do is get to display properties and advanced settings (right click desktop > properties > settings > advanced > video card settings > orientation) - you should find an option to change the orientation of the display - correct it accordingly. if the settings are not being saved after you restart, you need a video driver update - find it on your manufacturers website.
Jan 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Horizontal/Vertical Postion of Image on LCD Monitor
the controls for focus adjustment are on the flyback transformer, (that big black thing on the left hand side (usually) of the monitor with the thick red wire that goes to the CRT.) the flyback may have 1,2,3 or even 4 knobs on it. 3 of these would be labled SCREEN (bottom knob of flyback. handles brightness)
FOCUS 1 + FOCUS 2 (focus adjustments. these are what you need to play with) and the 4th knob (some old mitsubishi workstation monitors had these) i do not know, it wasnt labled and HV adjustment was on the deflection board
Apr 25, 2008 | Gateway FPD2275W LCD Monitor
Westinghouse LCD monitor
flicker to which side, horizontaly or verticaly. does it compress from both side or all side. only flicker from sides or from the center also??????????
provide proper information for solution
Feb 08, 2008 | Gateway FPD2275W LCD Monitor
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
Apr 14, 2006 | Dell 828FI 15" CRT Monitor
Compaq MV 500 Monitor Logo
Top Compaq Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Computer Monitor Expert? Answer questions, earn points and help others
