Question about Amana Heating & Cooling
How do you clean outside air coil - amana? - Amana Heating & Cooling
    President:
  • 2,976 Answers
There are a few coil cleaaners available for home use. They aren't as strong as what the professionals use but, they work well. They're available at the national chain hardware stores.
Posted on Sep 11, 2009
My amana ptc093b35ambp unit in a hotelroom will start but only blow warm air what should i check?
there is a run capacitor in the unit that needs to be check by using and ohm meter the rating is written on the front of the capacitor in mf called microsfarads. have you cleaned both of the coils the inside and outside. I would first take it outside and wash the units coils with a water hose you will need a spray attachment for the hose to get the pressure.
Sep 16, 2014 | Heating & Cooling
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
I have an amana ptac model pth153B50AM it does not seem to cool much at all but I do hear the compressor come on.Before i cost myself a couple thousand dollars can anyone tell me is this fixable?
yes it is fixable does the blower run? I would pull it out take it outside and wash with hose the outside coil and inside coil make sure you clean the outside coil real good on both sides. this may solve your problem.
Jul 30, 2014 | Amana PTH153B50AM Air Conditioner
Hisense reset
The outside vent must be OPEN to allow the appliance to get the needed air. In the heating mode of a heat pump, the outdoor coil becomes the condenser. Open the outside vent!
Nov 25, 2013 | Amana Heating & Cooling
I feel that my Amana 14000BTU is not cooling the living room enough, it is on 83farenheight, what can I do to make it kick out cooler air
Make sure the filter is clean and that the air flow to the inside and outside is not blocked. It could have a freon leak. See if the coils behind the filter are iced up. That's a sign of low freon.
Jul 22, 2011 | Amana Heating & Cooling
The dryer simply doesn't dry my clothes
Are the clothes warm after cycle? If not heater coils may be bad. Is lint trap cleaned out? Have you checked the vent that exhausts the air to the outside? make sure it is cleaned and kink free and the air is flowing freely. If you can get to the end of the vent outside you could try running the unit and check to see if you're getting good air flow outside from the vent.
May 27, 2011 | Amana Dryers
I have an amana air conditioner 2.5 ton ouside unit. Coil measures 130' degrees. How do you clean this. I was told it's clogged and should be 95 degrees.
Hello You can use a hose and wash/rinse the coil off.The temp of the coil is never the same on any given day! It also depends exactly where you take it, closer to the discharge input the hotter it will be and also how hot it is outside that day.130*f is never a bad temp.
Sep 02, 2010 | Heating & Cooling
My window air conditioner keeps freezing up
Have you cleaned the outside condenser coil you can clean it with a brush going up and down not sideways then rinse it with a water hose. Next clean the inside coild with brush and water hose. Sounds like an air flow problem. could also be low on charge.
Jul 02, 2010 | Amana Heating & Cooling
Should the unit be recharged at some point? I don't think my a/c is blowing very cold air, just cool.
Sometimes they leak and need to be recharged. There are other things to check first. #1 being filters. Then make sure your coils are clean, inside coil and outside coil. If all is well then you will have to get someone to check the system pressures to determine if it needs to be charged.
May 02, 2010 | Amana Comfort Zone 12M32PBEH Air...
Heating & Cooling Logo
35 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
