Washer will not spin during the wash cycle but will spin at the spin cycle. it is a kenmore 90 series washer model 110. please help.
  • 296 Answers
Hi, Most possible causes are:-
1.Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
2.If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
3.If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
4.After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
5.Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
6.Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one.
7.The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
8.The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
9.Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex.
Thanks! mannu_rakesh
Posted on Sep 12, 2009
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts. http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Sears 90 Series Washing Machined throws ground fault during spin.
pvatki, I am a licensed electrician and the NEC (national electrical code) does not require a clothes washer to be on a ground fault circuit interrupter. Replacing your gfci with a standard duplex receptacle will fix the problem you are having.
Dec 29, 2008 | Kenmore 15864/15862 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Dec 19, 2007 | Washing Machines
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
