Question about Refrigerators
Can't seem to adjust new refrig. thermostat
Am replacing defective thermostat in RV 3-way refrigerator... Bought after-market thermo to control A/C only. Installed it but won't turn off until it gets to about 10* and turning the control makes no difference...... So got another thermo (different make,etc) and it's acting the same....I'm going crazy! .... Hung each of them in our house refrig, they will not turn off in refrig, however they will turn off in the freezer....but no amount of dial twisting will make it go back on until you warm it up
Turn dial to warmest setting. be patient. wait two hours turn dial up another notch. be patient, wait one hour.ect until you get to setting 5 or 6. do not put food into frige until you have run it at least twelve hours.
Posted on Sep 12, 2009
Thermostat or temperature sensor seems defective
you might be right, its either your thermostat or your defrost timer. take down your model number and look up your part you need..Hope this helps you
Feb 18, 2013 | Amana Refrigerators
MSD2650KES SIDE BY SIDE REFRIGERATOR - BACK OF FREEZER ICED OVER AND REFRIG NOT STAYING COLD. DEFROSTED FREEZER, WORKED FOR A WEEK OR TWO NOW THE SAME THING...HELP
either the defrost heater located next to the evaporator core is burned out or the defrost timer unit is defective in the refrige compartment controls area or the defrost thermostat on or near the evaporator coil in the freezer is defective
Jun 08, 2010 | Maytag MZD2766GES Side by Side...
The freezer keeps freesing up and stops the air
Excuse me , but your fan works off 6-9 volts DC so do not try 120 volt cord . Your refrig has no defrost timer . It works off thermistors and a main control board .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off at selected temp.
May 26, 2010 | Hotpoint HSS25GFP Side by Side...
We have a duo-therm thermostat in our RV. We are using it now on the heat setting but it seems to be a large difference in temperature from when it starts the furnace and shuts off again. Is there a way to...
Probably ... this is really a job for a pro to adjust. considering the price of a replacement control, I think you should get a new control. With the new control in your hand, you might want to fiddle with it yourself. Find the adjustments inside.
Dec 30, 2009 | Dometic Rooftop RV Air Conditioner
Freezer and refrig both too cold. Adjusting the
If turning the freezer cold control (thermostat) all the way doesn't turn the compressor off then the thermostat is bad.
Dec 11, 2009 | Amana ARB8057CSL Bottom Freezer...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
