Question about Panasonic Televison & Video
Reset projector light timer on panasonic dlp tv
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Let me know exact model of your Panasonic DLP TV to provide you lamp timer rest info.
  • 110 Answers
All units have different ways to reset. seek out a manual to see the proper way to do it.
Posted on Sep 12, 2009
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
Reset timer panasonic d6000
Hello!
Have you bought bare lamp? Probably, yes. And not from "Panasonic"? yes. The timer's reset procedure is different for every model of Panasonic, including TVs. when you buy lamp with housing from Panasonic, they will give you the directions, how to. If it's "aftermarket", nope!
http://www.manualowl.com/m/Panasonic/PT-D5600U/Manual/52045
that's where you will find the procedure. it's quite complicated, page 45.
follow the directions.
good luck,
Alex.
Dec 27, 2011 | Panasonic PT-D5600U DLP Projector
I HAVE A PANASONIC PTD5600U WITH BAD LAMPS BUT THE PROJECTOR IS TOTALLLY DEAD NOW. I KEPT RESETTING THE TIMER BECAUSE THE LAMPS WERE STILL GOOD. NOW, I REPLACED THE LAMPS AND THE PROJECTOR WILL NOT POWER...
You may possibly find that running on duff lamps or lamps that are too old has killed the ballast unit.
Replace the ballast unit and fit a new lamp will probably cure it.
Hope that helps.
Dec 06, 2010 | Panasonic PT-D5600U DLP Projector
I have a new light bulb 7 months ago and i only have about 100 hours on it why will my projector not start
Have you reset the lamp timer?
If so, what is the status of the indicator LEDs next to the Power button?
Aug 15, 2010 | Panasonic PT-AX100U-EC DLP Projector
Reset the lamp timer
What model TV or Projector do you have. Most TVs and Projectors have the reset procedure from the remote.
Jul 02, 2010 | Dell 2400MP DLP Projector
Every 15 min or so my tv shuts off and a over temp light starts falshing on the front of my tv and the bulb has just been changed in january.
Hello!
Looks, like one of your temperature sensors has been damaged. May be due to severe overheating by old lamp. Or: the lamp could be improperly installed. Heats up, then connections to ballast fail, lamp quit working. Next possible cause: did you clean air filter? Vacuumed or blow fans with compressed air? Another possibility: If there was not a significant dust accumulation inside of lamp compartment, the ballast board itself can be at fault. In any case, unit might behave the way it does now. Also: have you reset the lamp timer? In projectors, they won't just give you annoying message via "on screen display". It might think, that you never replaced the lamp, just took it out and put back in. You must reset the lamp timer first. The procedure could be in owner's manual or come with OEM replacement lamp. Generics or "bare" lamps might lack that note. Panasonic wants to stay in a business!
Good luck with your project,
thanks,
Alex.
Jun 13, 2010 | Panasonic PT-D5600U DLP Projector
What does the red light mean?
The red indicator light usually comes on when something needs attention. Most often it has to do with the lamp timer or the filter timer. The projector keeps track of how long it's been since you've changed the bulb or cleaned the filter(s). You can reset these timers in the menu. Be sure to clean the filter before you reset the timer. :)
Jan 17, 2010 | Optoma HD65 DLP Projector
Lamp flashing, hd72 projector
In most projector menus there will be an option to reset the lamp timer, it's usually under the "settings" area of the menu. Try resetting the lamp timer and the light should stop flashing.
Jan 17, 2010 | Optoma HD70 DLP Projector
The tv shuts down and an orange light flashes
if it's the lamp led that is orange, turn off the projector for a minute and try it again. if the lamp goes out and the orange led comes on again, replace the lamp and reset the lamp timer.
Jul 25, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Televison & Video Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
