Question about Mitsubishi CS-40503 TV
Oversized picture problem
Recently my 40" mitsubishi tube tv started showing a larger picture than the screen will show therefore words and faces are not seen and or off the screen. i tried several things to change THIS but can't figure out the problem or solution. can anyone help? WE LOVE THE TV AND HAVE HAD IT FOR MANY YEARS WITHOUT EVER NEEDING TO MOVE IT OR REPAIR IT. THANKS FOR RESPONDING... Eddie
  • 139 Answers
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Posted on Sep 12, 2009
Picture tube for 60 in' mitsubishi it shows only a black screen but you can still hear it
ts will go into shutdown when a vertical issue is present but the audio will still continue to operate normally.
Apr 02, 2013 | Mitsubishi VS-50609 50" Rear Projection...
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
My Mitsubishi TV Model WT-46809 has the picture turn greenish pink after the TV has been on for a little while. What is the possible cause?
These sets did have one common issue where red, green, or blue would do what you are describing.
The set has 3 picture tubes and each has a small circuit board plugged to the bottom of it (bottom of the tubes faces down) and a ground would break loose or a part do the same.
I would examine the picture (see if you can take one and post it somewhere for me to see---picture will tell me a lot).
The ones with the ground broken usually show it more on the sides then in the middle of the screen.
Let me know all you can.
I am a top expert on this site.
Mar 19, 2012 | Mitsubishi WT-46809 46" Rear Projection...
My tv is showing to much red on screen
I don't have a lot to go on. If this is an older rear projection, this usually means the face of the green picture tube is dark (the picture goes purple-red) or there is too much red tube(excessive drive). This is a technical adjustment as it is in an area containing hazardous voltages. Adjustments will be a stop gap as rear projection TVs are all past their usable life span (About 8 years + with moderate use)
Mar 21, 2010 | Philips Televison & Video
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
The entire picture does not show on the screen
CHECK SMALL TRANSISTOR LOC.# 7571 OR 7406 AND COIL 5405 AND COIL 5402 CHECK CAPACITOR # 2404 AND2552 OR BUY A KIT FOR THIS TV IS COST A ROUND 8 DLL YOU PROBLEM YOU HAVE IN HORIZONTAL CIRCUITY IN YOKE CONECTION CHECK A RAUND
Sep 09, 2007 | Philips 32PT5441/37 32" TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Picture too dark
There are only 2 chips for colour convergence in this unit. there is also a screen control on each tube but most of all there is a bleeder assy. that can control the brightness.
Dec 14, 2006 | Toshiba 57H82 57" Rear Projection...
Televison & Video Logo
255 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
