Question about HP LaserJet 2200D Printer
How do you print divider tabs
Trying to print 5 tab dividers on a HP 2000D?
  • 1,049 Answers
Depends on the size of your tabs...
In Microsoft Word:
Pull down the tools menu and select "Letters and Mailings" and then choose "Envelopes and Labels", choose the labels tab, and select "Avery 5836 - Divider -Mtg. Creator" or manually set a height of 0.5" and a width of 1.75".
In any Word Processing Application:
Make a table 10x1, set the row height to 0.5", and then set every other column width to 1.75" and 0.5" respectively with a 0.5" left and right margin, 1.0" bottom margin, and a 2.0" top margin. Add rows until you fill the page.
Hope this was helpful and remember to vote...Thanks
Posted on Jul 28, 2008
5/6 divided by 11/12 is the same as 5/6 times 12/11 which is
10/11. 10 divided by 11 is___________.
Sep 24, 2015 | Cars & Trucks
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
Dec 18, 2013 | Texas Instruments TI-30XA Calculator
How do i solve this factorial equation? 8!/5!x3!
How to calculate 8!/(5!3!)?
For small numbers (8,5,3) you can use the factorial function key (I will tell you later how to access it) and enter 8! divided by 5!, divided by 3! For numbers greater than or equal to 70 you cannot calculate the factorial: the result is too large for the calculator's memory.
However the formula you wrote is an instance of a combination 8C5 or 8C3 (they have the same value.
Most scientific calculator have three functions: the n Factorial n!, the Combination function nCr and the permutation function nPr.
  1. Turn Calculator ON
  2. Select the Run icon and press EXE.
  3. In Run Screen Press the OPTN key
  4. Press F6> to pan to the other tabs
  5. Press F3:Prob
The first tab (F1) is marked x!.That is the factorial.
The tab (F2) is marked nPr is for the permutations
The tab (F3) is marked nCr and it corresponds to the combinations.
To use nPr or nCr you enter the larger number n, you press the F key under nPr or nCr. If you press F2 you see a fat P, if you press F3 you see a fat C. Complete by entering the value of r (the smaller number)
If your problem corresponds to Select 8 objects, 5 at a time regardless or order (combinations) you type 8 F3 5 and EXE Result is 56.
Aug 31, 2012 | Casio CFX 9850GA Plus Calculator
I am trying to divide a whole into a smaller number that is a decimal, any help? The question is 5 divide into o.45
You didn't specify the make and model of your calculator, so I can't give you an exact keystroke sequence.
The calculator doesn't care whether a number is a whole number or not. Just do the division.
On most algebraic-logic calculators, to divide 5 into 0.45, press . 4 5 / 5 =
On an RPN or RPL calculator, press . 4 5 ENTER 5 /
On most algebraic-logic calculators, to divide 5 by 0.45, press 5 / . 4 5 =
On an RPN or RPL calculator, press 5 ENTER . 4 5 /
If you still have problems, please reply to this post specifying the make and model of the calculator you're trying to use.
Mar 14, 2011 | Office Equipment & Supplies
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
2 of the 3 dividers in the dryer drum has come off. How do I screw them back in?
You have to disassemble the dryer partially to get the dividers back on.
There are two screws holding the door on, and it is slightly hooked in, take it off.
Take off the two screws on the opposite side.
Remove the front panel, pull out lift off tabs on bottom.
There are two hooks at top corners holding top down, 5/16 bolts I think on each side.
This allows room to reattach dividers when you raise top up, screws that came out should be laying on bottom of dryer. About two in each one, find four screws. Turn drum by hand to align for reattaching the dividers.
Important that you have unplugged and watch out for sharp edges.
Feb 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need to print divider tabs for a career portfolio. How do I do that?
Are you speaking of small file folder labels?
Generally, you can purchase the labels in page format and then use an application such a MS. Word or Corel's WordPerfect.
The application will control the placement of the spots on the labels.
Nov 12, 2009 | HP LaserJet 2200D Printer
Printing Avery Labels
click on "mailings" then labels. Then set up your lables
May 27, 2009 | Microsoft Office Word 2007 Full Version...
Math problem
it will be 49 divided by 3.243 = 15.10946654 or 15.11
Feb 07, 2008 | Office Equipment & Supplies
HP LaserJet 2200D Printer Logo
2,927 people viewed this question
Ben Johnson
